AT PSU rebuild
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    AT PSU rebuild
    I noticed that barney is looking for a good AT psu so I decicded to rebuild a generic crapy one I have laying around, just to see if it works out. Might be good for some old Pentium retro rig.
    I replaced the EMI filter components, added a 4A graetz bridge, E13007 primary switchers, Samxon 470/200 primary caps, EI35 transformer, MBR3045 for 5 volt and SBL1660 for the 12 volt rail. Added the missing pi-filter coils. Yageo SY and Arcotronics ESX caps.
    Had to replace two small 4.7uf and 22uf caps, I put Nippon KME there.
    ...also I fited bigger heatsinks and a temperature controlled fan circuit. I'll put the pcb into a grey anodized Skyhawk psu case. It has holes for both the AC switch and the periphelial cables. This desing has an LM494 pwm chip an a few transistors for the regulation. I'll add a 220k trimmer to where just two resistors where soldered underside the pcb for voltage adjustment.
    I hope my modifications worth it and this thing will live
    Also cabe gauge will be awg18 for the periphelial and the AT style motherboard connectors.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: AT PSU rebuild
    The big uncertainties may be whether that new transformer is sufficiently similar to the old, smaller, one, and whether those output caps are good enough but not too good (which might mess up the loop compensation). If that's a new output inductor, there may be compatibility issues there as well. But for adding robustness, I think you've accomplished that.
    PeteS in CA
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Re: AT PSU rebuild
      For the inductor i wouldn't worry - i've tested a bunch of output inductors of various sizes from cheap halfbridge PSUs and all had the same values.
      A working TV? How boring!
      • PeteS in CA
        • Aug 2005
        • 3581
        Re: AT PSU rebuild
        I remember seeing your post to that effect. The P/S pd rebuilt is nearly 14 years old (the date code on the PCB is "9816", 16th week of 1998). I was just wondering whether output inductors have been more or less identical for that long.
        PeteS in CA
        • pdavid
          • Jan 2011
          • 279
          • Hungary
          Re: AT PSU rebuild
          The supply is an ancient UTT model. The output inductor has the same size as the original. The only differance is that the two 5V windings are a bit thicker. Right now I'm looking for white and blue wires for the AT motherboard connector... though the originals would be fine as well for those.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Re: AT PSU rebuild
            Considering that the Chinese keep using the same early 90s designs for their cheap PSUs, there's a good chance they've been like that from the get go.
            • PeteS in CA
              • Aug 2005
              • 3581
              Re: AT PSU rebuild
              The places where P/Ss are built has been shifting over the past 3 decades or so. In the late 70s, Boschert was building production P/Ss in Sunnyvale, CA (Silicon Valley). I'm sure they weren't the only company building P/Ss in the US. Production has since migrated to (then) lower labor cost places like Mexico, Japan and Taiwan, and then to even lower cost places like Thailand, India and China. Putting it in perspective, the target price for power supplies in 1980 was ~$1 per watt. IOW, the cost to the computer manufacturer for a 250W P/S would have been $200-$250; in 2000, Delta Products sold 250W P/Ss to Compaq or Dell for $13 or $14 or to Apple (who had some unique aspects in what looked like a standard ATX P/S) for $14 or $15. And competitors were under-selling Delta on price (but for, then, lesser quality). So when things like inductor inductance values/winding ratios, cores, and transformer ratios and pin-outs became more or less identical is uncertain to me.
              PeteS in CA
              • pdavid
                • Jan 2011
                • 279
                • Hungary
                Re: AT PSU rebuild
                It's finished! Sort of... I've turned it on, voltages were good (except for -5 and -12, these were low) and I noticed that the fan spins faster and faster. The primary switchers were cool, but the secondary heatsink got so hot I could see the heat. The thermometer read 79C! Also there was an audable buzz coming from the trafo. So I put back an EI-35 transformer and it runs cool now, without load. Maybe I'll take it to work to measure ripple and stuff.
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  Re: AT PSU rebuild
                  Remember that the -5V and -12 may be regulated by 79XX 3-terminal regulators, which are 5% devices. Or if it's a reeeeeeally cheap piece of @#$% those two outputs might not even be regulated.
                  PeteS in CA
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    Re: AT PSU rebuild
                    Looking again at the pic, I don't see a 7905 or a 7912.
                    PeteS in CA
                    • pdavid
                      • Jan 2011
                      • 279
                      • Hungary
                      Re: AT PSU rebuild
                      Hooked up to a mobo and few hdd the voltages are good. Even the negative ones. Still, this psu is a low end at design and parts. A have a Sparkle and a Seventeam unit, now those are well built.
                      • Waffle85
                        Fujitsu Lifebook E756 vPro Bios Repair/Rebuild help
                        by Waffle85
                        I got a Fujitsu Siemens Lifebook E756 vPro with a corrupted Bios after flashing. Device wont start anymore, only Blackscreen.
                        Dumped the Bios and attached it. Maybe someone can help me repair/rebuild the bios?
                        Thanks in advance...
                        11-24-2023, 12:26 PM
                      • mferna14
                        Bin Files rebuild for HP Pavilion 17-cn1003ca
                        by mferna14
                        Hi, I am working on a hp 17-cn1003ca laptop., board # VLAD10-6050A3261101-MB-A01(A1).This laptop had gone to another repair shop & for no reason at all they just removed the BIOS chip (Chip missing). Checked the photo with identical board & no BIOS chip on mine & missing chip on these tracks. I downloaded the BIOS files from the Hp site for this model. The Model # is 17-cn1003ca & Serial # 5CG21832ZY. Can someone rebuild the Bin file for this Model & S.No. I have uploaded both, the 8MB & 16MB bin files, I think 16MB is required for this motherboard. Thanks in advance....
                        09-12-2023, 09:18 PM
                      • IDElectroRep
                        HP Pavilion 24-r111ne bios rebuild
                        by IDElectroRep
                        Hi
                        I need help with a corrupted bios. The pc doesn't power on with the original file. I downloaded new file from HP and the pc works but I get the "Manufacturer setup" display. I would really apreciate if someone could help with adding the missing data from the original to the new file. Thank you!
                        SN: 8CC8240QTT
                        post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                        05-07-2025, 10:28 AM
                      • retrooo
                        asus ga503q need bios rebuild asistence
                        by retrooo
                        good day to all, i have one asus ga503q that wont turn on only cps key blink for 3 seconds , i have one file from asus site but only gives me light on keyboard ,anyone can helpme to rebuild my original dump please
                        any help will be appreciated
                        thanks in advance...
                        02-02-2023, 08:23 PM
                        ZD desoldering station pump rebuild
                        by stj
                        just did one.
                        works great.
                        so here's the discoveries.
                        the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                        the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                        so you need to clean everything to get rid of all the tacky black stuff.
                        then reassemble it.
                        *BUT*
                        you must put the 2 screws into the assembly only finger-tight.
                        if you tighten it properly the valves dont work....
                        08-21-2024, 05:59 PM
