Did I make a wise PSU purchase?
  • Newbie2
    • Sep 2005
    • 885
    Today I was browsing through Newegg.ca and saw that they had the Antec High Current Gamer HCG-400 400W power supply on for just $49.99 CAD with free shipping, along with a $5 off promotional code (at the time of writing of this post). I saw the "All Japanese Brand Caps" feature in the product page and ordered this PSU in a heartbeat.
    I currently have a Neo ECO 400C 400W PSU powering my main PC (in my signature), and so I want to ask you guys, is the money I spent on the HCG-400 worth it to upgrade from a Neo ECO 400C?
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
  • c_hegge
    • Sep 2009
    • 5219
    Re: Did I make a wise PSU purchase?
    Yup. THe HCG series are good (provided that Antec didn't change their caps in secret)
    • dmill89
      • Dec 2011
      • 2534
      The HGC is definitely the better built / more reliable of the two, however I wouldn't really call it an upgrade, at least in the power provided sense. They are both made by SeaSonic, both based on the same platform (S12II), and both have the same rating. The HCG does have slightly better internal components (i.e. all Japanese caps) due to its slightly higher position on the Antec product ladder. If I was buying a PSU I would choose a HCG over a Neo ECO due to these better components, but I probably wouldn't replace a perfectly working Neo ECO with an HCG of the same rating.
      • Newbie2
        • Sep 2005
        • 885
        Thanks for the helpful feedback c_hegge and dmill89.
        I will definitely take the cover off my Neo ECO 400C once I get my HCG-400 400W, and post the pictures on the forum. If I can afford it, I might also look at getting good caps to replace the secondary caps, whatever they are, of that Neo ECO.
        My gaming PC:
        • mockingbird
          • Dec 2008
          • 5484
          Yes!
          Read my comments about these in my other posts.
          HCG-400 is a fantastic PSU. I have used these personally very recently... The power switch and socket is even upside down to accommodate the new bottom-mounted PSU cases.
          Only thing is that I found them to run a little warm. I would have liked there to be less heat-tolerant fan settings, it's just a bit too moderate. The 120mm fan inside the PSU is ball-bearing, I think.
          • c_hegge
            • Sep 2009
            • 5219
            The Neo ECO's caps are Only Some Trash IIRC
            • dmill89
              • Dec 2011
              • 2534
              That's about standard for SeaSonic's budget builds, I've also seen some reviews where Su'Scon was used on the secondary, so I guess the exact cap selection varies from unit to unit depending on build date but some brand of Taiwanese mediocre caps is to be expected on the secondary. While not the best these caps are generally good enough to last 5 years or so in a PSU.
              • Newbie2
                • Sep 2005
                • 885
                Well the upside is that those better capacitors in them will be able to withstand the heat without prematurely bulging and causing ripple to skyrocket.
                OST
                Su'scon
                Why I don't trust either brand of capacitor powering my big investment. (not my pictures)
                My gaming PC:
                • Newbie2
                  • Sep 2005
                  • 885
                  I received my HCG-400 from Purolator today, and installed it into my PC. Everything's running nice and smooth, and the voltages being read by my motherboard look good:
                  I shone a flashlight into my new HCG-400 before installing it and from what I could see, all the caps inside where Nippon/United Chemicon.
                  I also opened up my old Neo ECO 400C as well. The single primary cap is a Nippon Chemicon, however all other caps (secondary caps and small caps) are brown Su'scon caps. Too bad none of them were visibly bulging, but they're not something I'd trust.
                  I got peace of mind now that my PC has all good capacitors in it now, from my motherboard (all polymer caps) to my power supply (all Japanese electrolytic caps).
                  My gaming PC:
                  • dmill89
                    • Dec 2011
                    • 2534
                    I know the feeling. I have a Antec True-Power Quattro 850w built by Enhance in my primary rig. It is well built, and rock stable but the Teapo caps on the secondary don't instill me with endless confidence. Since It is still under warranty, has industrial grade protection circuits, and Teapo's don't have all that bad of a reputation in PSUs. I don't have any plans to recap or replace it at this time, however I would definitely feel better with a PSU that had all Japanese caps.
                    All the caps on my motherboard (Gigabyte EP45C-UD3R) are both Japanese and polymer so I am unlikely to have problems with them, which is good since the extra thick copper layers in the Gigabyte UD series makes it extremely difficult to de-solder / solder on these boards, they just suck the heat out of the iron.
