Corsair HX620W - dead APFC MOSFET
  • Clunche
    • Mar 2020
    • 12
    • France
    Hey guys, yes, two scopes are cool and I bought the 2235 back in 1989. I was working at HP at that time and I was perceived as an heretic to buy scopes from a competitor : ) But HP oscilloscopes, in my opinion, could never compete with the TEKs. I had to replace the flyback transformer on this one after 15 years of service and it was not fun to fix the self-relaxing supply: a cleverly-designed type but a mess to troubleshoot. Then I had the opportunity to obtain a TEK 2465B which was not working properly and I fixed it, good for another decade : )
    Now, without a scope, I could not fix most of the instruments or equipment I have been repairing for years. You truly need to observe the waveforms - especially in a switching converter, my specialty - to learn from it and infer what the issue it. I agree, a multimeter is also needed, but, in most cases, the lack of scope would have been an impeding factor.
    Regarding the PFC design, I agree with nomaka, it must be a fail-safe design. But these guys usually won't invest in an extra relay to short the front-end NTC and prefer to insert it in series with the diode as it minimizes the ac ripple and the rms component. A bad approach, I agree. I have also sometimes seen it in series with the bulk cap. and later shorted by a ground-referenced MOSFET. Again, not the best approach.
    Cheers, Christophe
    • Loulou31
      • Mar 2024
      • 5
      • France
      I agree with you, to fix problem on electronics an oscilloscope is necessary except for very simple problems. Even to check DC to.see unstability, noise, ripple a scope is mandatory.
      For oscilloscope it is ok for me also that Teks are better than HP. However I have an ( quite old!) HP1740 thats I like.
      Regards
      Jean-Louis
      • zunasthegreat
        Dead corsair VS450 with blown TNY chip (cwt)
        by zunasthegreat
        I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
        The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
        08-30-2025, 03:11 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
      • roxboy1984
        Dell E5530 completely dead and MOSFET getting HOT! Please help.
        by roxboy1984
        So I'm trying to fix the above mentioned dell laptop. It has no signs of life at all when plugged in. If I connect the AC I noticed the MOSFET PQ5 gets very hot. So I'm assuming there is a short somewhere. I'm still learning so please could someone assist me. Thanks for any help given.
        I did try swopping the Mosfet which is a AO4423 with one from a donor board being a SI4483ADY as they both have the same VDS @ 30V. once I swopped the Mosfet when I plugged in the charger it would just switch off so I swopped the MOSFET back....
        11-02-2022, 12:28 PM
      • quicknick
        Dead Corsair TX650M
        by quicknick
        PSU is made in late 2019 and seems barely used judging by the lack of dust on its innards.
        +5Vsb is all right, grounding PS_on results in a relay clicking and nothing more, all outputs dead without even a flinch.
        Checked inside, at first glance all seemed ok but then noticed something on the primary heatsink, which I promptly removed along with all its attached devices - there were clear signs of insulation breakdown above the C3D04060 diode. The device was overtightened from factory and the tab squished the sil-pad, it all was a matter of time,...
        10-09-2024, 02:52 PM
      • Nooy
        VGA MOSfet permanently shorted and loss of MOSfet pad
        by Nooy
        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
        02-14-2024, 02:26 AM
