I have an old ISO-400 PSU that I recently took out of service. I opened it up and there was one Fuhjyyu 1000uf 16V cap bulging, I replaced it with a Rubycon MCZ. All the other caps look ok. When I test it with a Coolmax PSU tester, all the voltage are correct. The first time I test it the Power Good is 480ms. When I test again right afterwards, I get a Power Good timing High. It works fine in service. I checked a number of articles on the web and the only place I find a tolerance for the PG timing is related to the the Coolmax Tester. Is the timing issue normal or should I examine it further? The PSU has a number of Fuhjyyu and Teapo capacitors. I'm keeping the supply as a spare for some of the old computers I am maintaining for my family, simple internet/business machines with onboard graphics.
Power Good timing question
Re: Power Good timing question
I wouldn't worry. It's usually because it was one of the last pins to make contact with the tester. I would always plug it in to the tester before connecting it to the mains, and it would never happen.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
I agree.
However, I would strongly advise that you change the Fuhjyyu caps. The fact that one Fuhjyyu is failed means the others may not be far behind.
Overall, the PSU may be okay if you just want to use it to test a PC for a few minutes. Any longer than that and you may be doing damage to the components in that computer.
Also, Rubycon MCZ is not really a suitable replacement for PSU caps. You need something with a little higher ESR than that. Rubycon YXG and ZL, Panasonic FC, FR, and FM, Nichicon PM, PW, and HE, United Chemicon LXY, LXZ, KY, and KZE, and Samxon RS are all better choices.
With that said, the Rubycon MCZ you installed is still a better option than leaving the bad cap in the PSU.Last edited by momaka; 11-25-2011, 11:01 PM.Comment
It's in Intel specifications somewhere.I have an old ISO-400 PSU that I recently took out of service. I opened it up and there was one Fuhjyyu 1000uf 16V cap bulging, I replaced it with a Rubycon MCZ. All the other caps look ok. When I test it with a Coolmax PSU tester, all the voltage are correct. The first time I test it the Power Good is 480ms. When I test again right afterwards, I get a Power Good timing High. It works fine in service. I checked a number of articles on the web and the only place I find a tolerance for the PG timing is related to the the Coolmax Tester. Is the timing issue normal or should I examine it further? The PSU has a number of Fuhjyyu and Teapo capacitors. I'm keeping the supply as a spare for some of the old computers I am maintaining for my family, simple internet/business machines with onboard graphics.
I think in the docs for VRMs.
Haven't read it for a while.
.Mann-Made Global Warming.
- Dr Seuss
Section 3.3.
The ATX spec 2.1 refers you back to this one for the timings.
Intel and these guys verbatim repeat each other on the topic.
Not sure which actually originated it.
- Dr Seuss
by sam_sam_samHere is where you can find one
https://www.ebay.com/itm/11450939852...53.m2749.l2649
I am not getting paid for this recommendation nor was it a free item from the seller
I have bought several USB A/C type testers are not worth a crap for USB C you have to connect it several times to a USB C device before it recognizes the device to me this is worthless
The only downside of this tester is that it does not tell you what protocol you are accessing but this to me is not a very big deal because I would... -
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... - Loading...
