Hello folks, I am trying to find a replacement Schottky Barrier Diode with part# YG805C06 for a power supply that goes in to a slot machine. Here's a link to the datasheet without the quotes. "http://www.datasheetcatalog.org/datasheets/50/285369_DS.pdf" Any ideas? Thanks.
Replacement Schottky Diode
by BasteHello experts,
Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
Aneng ST182 Meter.
Diode mode.
MBR3045CT:
Diode mode
Pin 2-1 - 0.150v
Pin 2-3 - 0.150v ...4 Photos -
by chth96is there any replacement for MPG06J diode?
https://www.vishay.com/docs/88682/mpg06.pdf
It is very hard to find this MPG06J diode in my place.
I think that replacement should have the same ratings with MPG06J, But it is impossible for me to hunt down replacement for MPG06J diode.
Any reply would be appreciated. -
by badcappoHi there, looking for a compatible replacement for a diode type labelled "V6 18" from a dead Panasonic plasma TV power source. Possibly a V6 600 volts diode as seen here: https://electronics.stackexchange.co...nt-diode-v6-88 ?
Thank you
by asrHello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks.... -
by iyas132Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
Can anyone help me identify the component...1 Photo - Loading...
