Power supply voltages??
  • BossTone74
    • Jul 2004
    • 18
    Is this going to be a major problem?
    12v is at 11.65
    5v is at 4.95
    3.3v is at 3.33
    2.5v 2.54
    vcore 1.5
    Bosstone74
  • tiresias
    • Feb 2006
    • 489
    Re: Power supply voltages??
    No, assuming you measured these with a relatively accurate/calibrated meter... they are within standard 5% tolerance of ATX specifications.
    Besides, the 2.5v (DDR DIMM), and Vcore are not outputs from the PSU but from the motherboard's CPU and DIMM VRMs...
    • linuxguru
      • Apr 2005
      • 1564
      Only the +12v is slightly out of spec, but it's still OK. You may want to recalibrate the PSU by adjusting the voltage regulation preset inside the PSU, if it has one. I usually set +5v to 5.05v (+1%) to care of cable/connector drops, etc.
