Anybody knows which power supplies to consider (and which ones not) in terms of quality of capacitors used ? For a MOBO you can open the box/packing and look at the capacitors to see which mobo has what caps but for a psu you'd only know from people who have had a chance to open one and looked inside. Anyone has any information regarding this ?
Power Supplies with good caps
Re: Power Supplies with good caps
Zippy/Emacs, Lite-On/Ablecom/Supermicro, Delta, AcBel/Coolermaster/Asus, Etasis, and Seasonic seem to be the best for caps, though Seasonic doesn't always use the good stuff. Often the cheaper the PSU, the better the chance it will have less reputable caps in there.
Most of the time Chemicon turns up in the above units, though I have seen something like a Capxon or two for the smaller caps. -
BTW, Silverstone PSUs are made by Etasis. At least their ST30NF fanless is. So we don't need to worry about caps failing ion that PSU.Comment
Originally posted by Chris1992BTW, Silverstone PSUs are made by Etasis. At least their ST30NF fanless is. So we don't need to worry about caps failing ion that PSU.
Antec uses OEM Channel Well units for most, Seasonic for the Neo HE line. Channel Well loves Fuhjyyu with the odd cap being Teapo or Capxon, while the Seasonics used for the Neo HE's are mostly Teapo. Thus my comment about Seasonic not always using the best. Some old Antecs were HEC/Heroichi/Compucase as well.
Fortron-Source varies... they seem to shift between cap makers. My FSP530-60GNA is all Teapo, while my FSP600-80GLC is mostly Capxon with a few OST. Low end models have had the odd Fuhjyyu and Jamicon in there too. Usually their units are quite reliable despite the choice of cap.
Note that Inwin Powerman is no longer Fortron - they make their own now. All OST caps from what I've seen.Comment
Assuming...7 Photos -
by eryjusHello,
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by jake-bgood morning all,
i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
