FSP300-60GHSR - 300 Watt 80Plus SFX12V PSU
The secondary caps are all OST RLP.
7x 1000uf 16v 8x20mm
2x 2200uf 6.3v 8x21.5mm
They're custom sizes so the RLP series datasheet doesn't list them. The closest are RLP series in 10mm diameter.
The 16v cap has 1050mArms ripple with impedance of 0.068 @ 100KHz.
The 6.3v cap has 1220mArms ripple with impedance of 0.041 @ 100KHz.
I don't think it is possible to use 10mm diameter capacitors. Does anyone know of caps that will work well without messing with the pi filters? It seems no one even carries capacitors with 8mm diameter with 5mm lead pitch in similar capacitances other than Nichicon HM,HN,HZ.
