powersupply noisey fan after clean up?
  • newtoCaps101
    • Jul 2011
    • 93
    hi, i have a silverstone 600w psu, about a year old. I recently opened it up, removed the fan and cleaned everything up only to find that the 120mm fan is now making considerable amount of noise, as if its running at full speed. I have never noticed this before but its very annoying. The psu says it has fan sensor control so the only explanation I can think of is maybe its sensor has gone bad now causing it to run at full speed?
    what should i do? any way to fix this?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: powersupply noisey fan after clean up?
    here is what you can do:
    take the cover off the unit but leave the fan connected if it is a lid mounted fan. if it not a lid mounted fan, then remove the fan but leave it plugged in. next, find on the fan where the wires are soldered to the little circuit board (you may need to peel a small amount of the sticker up to get to it). connect power to the unit and on the atx plug, short the green wire to ground with a jumper. this will turn on the psu and start the fan. use a multimeter between the red and black wires on the fan's PCB and see what you get.
    a word of caution, when the cover is off a live PSU, you need to wear shoes and avoid touching the heat sinks inside the PSU. the primary one has 120vac (240 in some countries) at it and if you touch that, especially barefoot on a metal or concrete floor, you will get a nasty shock... safety glasses are also recommended.
    anyway, post what you get. this is the voltage the presumably 12v fan is running on.
    sigpic
    (Insert witty quote here)
    • mathog
      • Mar 2010
      • 2655
      Inspect the fan header and plug carefully. If the speed sensor pin is not making a good electrical connection you might see this. It is a power supply, so take the appropriate safety precautions.
      If it is a standard 12V 3 pin plug you can test that the sensor line is working properly by removing the fan from the PSU and plugging it into a 3 pin header on a motherboard that supports fan speed monitoring in the BIOS.
      • 999999999
        • Sep 2006
        • 774
        See if it is really running at high RPM or just noisy because the bearing ran dry or fan shaft washer came off and now has play in it?
        At no load or very low load condition, measure the voltage at the fan connector. Check the fan label to determine bearing type. If it's an ADDA fan see this:
        https://cdn.badcaps-static.com/pdfs/...174352e222.pdf
        If it has a "hypro" or "S" (sleeve) bearing, pull the sticker back, pull the plug out and put a couple drops of thick oil in, turn the blades by hand a few revs, and put plug and sticker back on.
        Is it possible you had cleaned it with liquid and that created a flux solution that shorted the fan control circuit (could remain shorted even after it dried as the flux can make a metallic conductive pool of solution that concentrates as it dries).
        I don't know the sensor circuit in that PSU, but if it has a thermistor and transistor and you caused ESD during cleaning, I'd replace the transistor with any having roughly same spec (need not be exact same, probably 1/3rd of all 20 cent transistors you can find would work once you know current, voltage, PNP vs NPN type, etc).
        • newtoCaps101
          • Jul 2011
          • 93
          thanks everyone
          I replaced the fan
          • CapLeaker
            AcuRite 5 in 1 temperature sensor replacement repair
            by CapLeaker
            Got a new victim:
            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
            B: stuck at some temperature and maybe updating once in 12 hrs or so.
            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
            04-15-2025, 01:32 PM
          • groomit
            Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
            by groomit
            I just replaced the battery on a Google Pixel 5.
            After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
            Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
            The rubber seal is on again (as mentioned in various suggestions in other forums).
            This smells like a cold or broken solder joint. So I'd like to reflow...
            06-11-2025, 02:21 AM
          • Gcnewbie
            Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
            by Gcnewbie
            Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
            I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
            My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
            I opened the...
            03-29-2024, 06:55 AM
          • otoluk
            Auriol weather station humidity sensor
            by otoluk
            I have two Lidl LD6273 Auriol units with DCF77 radio for time update.
            I really like the idea but the cheap moisture sensor(guess HR202L) inaccuracies make the device unreliable. Also not clear why indoor and outdoor unit sensors being same type doesn't match. For example I place both units on same table and indoor unit shows 23% humidity while outdoor sensor shows 39%. What I found out is that I get better readings if cleaning the solder points of sensor inside with isopropyl alcohol.
            Looking for replacement sensor which I could solder in place of HR202L resistive sensor but need...
            11-06-2024, 07:57 AM
          • corrize
            Soldering plastic low profile FPC close camera CMOS sensor ?
            by corrize
            Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
            CMOS sensor seems resist to high temps.
            But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
            I have low melting point solder.
            I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
            07-12-2024, 02:21 PM
