ISO-P500SPP Passive PFC capacitors
  • Devis
    • Jul 2011
    Hi all.
    I've a problem with my old Sunny Technologies PSU (model ISO-P500SPP). After it didn't power on anymore, I opened it and saw that a capacitor mounted in passive PFC board was exploded, a fast diode beside it was in short circuit and fuse was blown. I replaced fuse and diode (FR157).
    I replaced capacitors too (marked Teapo 2,2uF 400V SEK105°C) with two 450V 85°C capacitors, but after a while they went in leakage another time. I'd like to ask you if I'd need to use low ESR or any other special type of electrolytic capacitors.
    I attach a part of schematic I designed about PFC part.
    Thanks in advance for any help
    Have a good day, Devis
  • lti
    • May 2011
    • 2552
    Re: ISO-P500SPP Passive PFC capacitors
    How long did it last before the replacement caps blew?
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Just remove those caps and disable that part of the circuit. This is my treatment to this problem:
      https://www.badcaps.net/forum/showth...?t=8171&page=6
        master hoarder
        • May 2008
        • 12175
        +1
        This PPFC is technically supposed to boost efficiency a little bit when the PSU is off. In reality, though, it wastes A LOT more power than it saves. This can be quite evident by the heat it outputs.
        Like goodpsusearch said, just disable/remove it. Getting rid of the capacitors is sufficient, but if you want to add some spare resistors and diodes to your junk box, remove the FR157 diodes and 2W resistors as well.
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • Larrob19
          Samsung TV UN75NU7100/Power Board BN44-00874C
          by Larrob19
          I have a Samsung power board BN 44–00 874C that is dead. I have looked for a schematic but no such luck. I opened it up and found two Mosfets burnt QP801CS and QP802CS, also the main fuse. I replaced them and checked the two blue capacitors in front of them. They both tested good. I checked the Diode on the same heat sink and the two capacitors in front and they checked out OK. I plugged it in again and that blew the fuse and the Mosfets the second time. I plugging it in again hooked to a 100 W watt light bulb. The light bulb starting started flashing off and on. I checked...
          05-08-2025, 12:49 PM
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
