I have a Aug 2004 G5 Tower. Push power button & nothing. Tried the little pmu and unplugging, no better. Phone tech's all say power supply likely gone. I have a power supply from a June 2004 G% tower that has one number different from mine, a gift from work IT guys I just had to remove it. Part # on Aug 2004 is 614 - 0307 and part number on the June 2004 is 614 - 0306. Both are 600 Watt. All voltages match on both labels but are in a different order. Manufacturer different. Will these interchange or am I running the risk of cooking the guts of my G5? Thanks for any input. Wayne
G5 power supply partnumber exchange?
Re: G5 power supply partnumber exchange?
OK I have tried everything that I can think of and the G5 will not go past the gray screen with the apple logo. No spinner and thats it. Chimes every time I start up but if I hold any key down to try a safe start I get chimes and a red led inside comes on and nothing else. No gray screen, nothing.I have to unplug the machine for a few minutes to get it back to where I get only gray screen and apple, Am I/it cooked? Any suggestions are welcomed and I am begging for enlightenment. Thanks for all the patience and suggestions. WayneComment
Only difference with the psu is that the G5 would not turn on before I swapped and now I can get chimes and a gray screen with the apple logo, no spinner. I pulled and reseated all ram and swapped HDD with another one that I have. I can feel boh drived spinning
s and they both generate heat after a few min of operating. All fans are working. I tried to satrt from DVD with no luck. Nothing but chimes and no screen activity, same when I reset PRAM and try to start in safe mode.
Thanks for your input, More Suggestions?Comment
Try putting in the OS Disc 1 and run the disk utility. May have lost the boot info. Hold down mouse on power-up to eject CD tray. Then load CD and power-cycle and hold down C to force boot from CD. See if disk util can find hard drive.veritas odium paritComment
Only tings connected are Apple mouse and keyboard and ViewSonic display. All have been connected to G% with no issue in the past. Running 10.4.?
Have tried to get machine to boot from DVD. Will get chimes once and nothing. No image on monitor nothing. Will do nothing different until I unplug for a while and replug, then I can get back to the gray Apple with no spinner.
Am lost. thanks for the suggestions, please keel them coming.Comment
If you have access try //support.apple.com/kb/TS2570 for complete info on this problem. If all your know-goods are in fact good, focus on 3rd party RAM and internal hardware if any. Bad news is you have pretty well gone down the list of things to check already so these are just an outside shot. OS reinstall would remove any doubts on drivers, etc. Lucky you, sounds like you have "one for the books"Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
