G5 power supply partnumber exchange?
  • Poppy
    • Jun 2011
    • 4
    I have a Aug 2004 G5 Tower. Push power button & nothing. Tried the little pmu and unplugging, no better. Phone tech's all say power supply likely gone. I have a power supply from a June 2004 G% tower that has one number different from mine, a gift from work IT guys I just had to remove it. Part # on Aug 2004 is 614 - 0307 and part number on the June 2004 is 614 - 0306. Both are 600 Watt. All voltages match on both labels but are in a different order. Manufacturer different. Will these interchange or am I running the risk of cooking the guts of my G5? Thanks for any input. Wayne
  • Toasty
    • Jul 2007
    • 4171
    Re: G5 power supply partnumber exchange?
    PowerMac G5, I'm assuming???
    Yes, PSU's are interchangeable.
    Manufacturer's of the 2 units? 0307 LiteOn? 0306 AcBel?
    Would be interested in dead unit if you're not.
    Toast
    veritas odium parit
    • Poppy
      • Jun 2011
      • 4
      OK I have tried everything that I can think of and the G5 will not go past the gray screen with the apple logo. No spinner and thats it. Chimes every time I start up but if I hold any key down to try a safe start I get chimes and a red led inside comes on and nothing else. No gray screen, nothing.I have to unplug the machine for a few minutes to get it back to where I get only gray screen and apple, Am I/it cooked? Any suggestions are welcomed and I am begging for enlightenment. Thanks for all the patience and suggestions. Wayne
      • Toasty
        • Jul 2007
        • 4171
        Swapping PSU made no difference?
        RAM modules in place? HDD installed?
        veritas odium parit
        • Poppy
          • Jun 2011
          • 4
          Only difference with the psu is that the G5 would not turn on before I swapped and now I can get chimes and a gray screen with the apple logo, no spinner. I pulled and reseated all ram and swapped HDD with another one that I have. I can feel boh drived spinning
          s and they both generate heat after a few min of operating. All fans are working. I tried to satrt from DVD with no luck. Nothing but chimes and no screen activity, same when I reset PRAM and try to start in safe mode.
          Thanks for your input, More Suggestions?
          • godonr
            • May 2009
            • 111
            Have you tried starting with all peripheral devices disconnected except k/b, mouse and display? also, what OS are you using?
            • Toasty
              • Jul 2007
              • 4171
              Try putting in the OS Disc 1 and run the disk utility. May have lost the boot info. Hold down mouse on power-up to eject CD tray. Then load CD and power-cycle and hold down C to force boot from CD. See if disk util can find hard drive.
              veritas odium parit
              • Poppy
                • Jun 2011
                • 4
                Only tings connected are Apple mouse and keyboard and ViewSonic display. All have been connected to G% with no issue in the past. Running 10.4.?
                Have tried to get machine to boot from DVD. Will get chimes once and nothing. No image on monitor nothing. Will do nothing different until I unplug for a while and replug, then I can get back to the gray Apple with no spinner.
                Am lost. thanks for the suggestions, please keel them coming.
                • Toasty
                  • Jul 2007
                  • 4171
                  Check PSU output voltages when connected to machine.
                  In standby mode.
                  In power on mode.
                  veritas odium parit
                  • godonr
                    • May 2009
                    • 111
                    If you have access try //support.apple.com/kb/TS2570 for complete info on this problem. If all your know-goods are in fact good, focus on 3rd party RAM and internal hardware if any. Bad news is you have pretty well gone down the list of things to check already so these are just an outside shot. OS reinstall would remove any doubts on drivers, etc. Lucky you, sounds like you have "one for the books"
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • CMCM
                      Russound CA4 Power Supply Repair
                      by CMCM
                      Hello Everybody,
                      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                      The outputs marked 12v and 20v are all measuring only 1v.
                      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                      The capacitors physically look clean (no bludgesor leaks) and...
                      07-03-2025, 01:12 PM
