Dell voltage tolerance
  • choffman41
    • Jun 2011
    My GX280 has the usual problem and before changing out caps, I would like to be sure its not the ps. The 12v. leads all measure 11.8v. I know that is within tolerance, but is it possible that these Dells are really finicky about voltage?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Dell voltage tolerance
    Nope. Relace ALL caps if they have failed.
    • choffman41
      • Jun 2011
      Unfortunately, all the caps look perfect. I guess since there are both X and K, I'll replace the X's first and see what happens.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Ferimonka
        Dell Latitude 7420, 7320 voltage changed
        by Ferimonka
        Hi there,
        I got 2 Dell laptops with a locked bios (dell management protection).
        When I sent the dumps to this forum I got unlocked .bin files.
        The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
        Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
        I appreciate any help to get me this...
        07-18-2022, 02:11 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • 13mh13
        Dell Inspiron 5100 (2003) with RAM issues (voltage, PSU suspect ??)
        by 13mh13
        Here's my device:
        LAPTOP: Dell Inspiron 5100 (2003) 2.4Ghz p4, dual-boot: Windows XP pro, sp1 + LinuxMint ( LM 17.1 MATE ), with 128GB ssd, 512mb ddr sodimm.
        The 5100 runs fine, even after 19 years of daily, gentle use, "always on", and on adapter power only.
        HOWEVER, over the past 5-6 years there has been a restart-up issue (after power down or power loss --- I leave all my PCs/laps in daily use in ALWAYS-ON condition, even going months w/o re-boots, but the inevitable always happens) .
        Seconds to few mins after pressing the power button to restart...
        06-06-2022, 08:44 PM
