UPS with ferroresonant transformer acts like PFC?
    I think a UPS unit with a ferroresonant transformer (one which is connected in parallel with the battery-backed sockets) would act like a power factor corrector (PFC). Would this make a non-PFC power supply as efficient as a PFC power supply?
    Re: UPS with ferroresonant transformer acts like PFC?
    No.
    Rest in peace BFG. You were... a job...
      pfc doesn't make things more efficient it, power supply with pfc are higher quality, that's what makes them more efficient not pfc, it actually decreases efficiency just a little bit. All PFC does is not mess up the power grid by making its self look like a pure resistor. I know you didn't know, but now you do
        The Second Law of Thermodynamics, translated into plain English and personalized, means that no matter what you do in life, you lose something. In power terms, anything you do, rectification, a transformer, the power switches, the inductors, the caps, etc. consume at least some power, converting it to heat. This means that when you place a PFC stage in front of the switching regulator, you reduce the efficiency of the over-all power system. A UPS, regardless of topology, is less than 100% efficient. Thus the answer to the question of whether adding a PFC stage or adding a UPS is more efficient boils down to the respective efficiencies of each. I suspect a PFC stage is the more efficient, since it is doing less.
        So, what is the point of PFC? Without it, the AC I/P current is high magnitude spikes conducting only at the peaks of the voltage waveform. In a large facility (or neighborhood) full of computers, this can lead to high copper losses in "line" wires, high currents and losses in "neutral" wires, and flat-topped voltage waveforms on the AC power throughout the building. Passive PFC reduces the magnitude of the current spikes and lengthens their duration; active PFC can make the AC current close to sinusoidal or better.
        PeteS in CA
          For big consumer of elektricicity, it is a mather of money to have a god power factor (at least in Germany). Low PFC increase the power, the plant have to deliver.
          PFC regulation dosn`t do mutch on efficiencie, may be it degrades it a bit. But if you have to pay for the blindpower, then it is costefficient to have a pfc regulation in any way.
          Pasive PFC means to place an inductor in series with an capacitor, thus an ferroresonant transformer or simple bulb balast can do the job if it has the proper size.
          On the other hand, if used for incadeszent bulbs they compensate it with an capacitor in parallel, but most big companies bay EVG or electronic balast, due to the better efficiency, less flikering and an pfc of 0,99.
            Common practice for pulp mills where I grew up is to run a synchronous motor with an over-excited field or some cap banks or a combination of the two for PFC...
            Home users are not charged for poor PF in BC, only industrial users.
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
