iMAC G5 ALS PowerSupply API4PC46-290 REV.A R37 near 3845B
  • Toasty
    • Jul 2007
    • 4171
    Re: iMAC G5 ALS PowerSupply API4PC46-290 REV.A R37 near 3845B
    Q1 fails are not -that- common and are distinguishable by a clouded bar on the package surface in line with the collector. (or blown to smithereens ) That invariably means the voltage went to high because of the bad caps, causing the 3845 internal (protection) zener to trigger causing Q1 to overcurrent. *poof*
    What has been done to this new supply?
    veritas odium parit
    • torgeson5kqs
      • Mar 2011
      • 116
      I've checked all the caps on the secondary side of the unit (ones that normally bulge) they all check out according to the ESR meter. This is the first supply I've run across that did not have bulging caps that was bad. The only thing done was the replacement of the Q1. All the caps are Ltec, but again they are within tolerance on the ESR meter.
      • Toasty
        • Jul 2007
        • 4171
        ...and the little ones as before? Replaced?
        Does it even try to start? Meter the outputs and see.
        >>they all check out according to the ESR meter.<<
        According to Ltec's sheet?
        veritas odium parit
        • torgeson5kqs
          • Mar 2011
          • 116
          The caps below with voltage readings have all been replaced with Panisonic FC caps. I still just get standby voltages on pins 9 and 22 both in standby and when "ON". All the other Ltec caps in the secondary part all meet Ltec Max impedence specs on this url measuring with Blue ESR meter http://www.ltec.com.tw/lyz.PDF
          1st is standby, 2nd value is "On"
          C1 - 0, 0
          C11 - 0, 0
          C37 - 21.3, 21.4
          C69 - 5.7, 5.7
          • Toasty
            • Jul 2007
            • 4171
            Locate and measure voltage from output negative to Pin 2 of opto M3 while in standby as follows -
            Orient the board with the solder side facing you, the outputs to the left and the hot to the right.
            There is a vertical slot in the board for isolation of "HOT" and "COLD" power.
            The opto's sit across this.
            Looking from top to bottom they are:
            M3
            M4
            M11
            M7
            At M3, the square pad is Pin 1 and the one above it is Pin 2. (Just to the left is Diode D1)
            Report voltage please.
            veritas odium parit
            • torgeson5kqs
              • Mar 2011
              • 116
              #26
              I get a reading of 4.6 volts at pin 2 of M3 in standby mode.
              • Toasty
                • Jul 2007
                • 4171
                #27
                Good.
                Obtain a 1/2w or better resistor with a value between 33 and 68Ω.
                Connect a jumper wire (alligator clips) from output negative to one leg of the resistor.
                Monitor the 3.3v, 5v, & 12v output voltages with your meter(s).
                Briefly touch the other leg (ungrounded) of the resistor to M3, Pin 2.
                The supply should come on.
                Note each voltage and report.
                veritas odium parit
                • torgeson5kqs
                  • Mar 2011
                  • 116
                  #28
                  Only pin 15 came on at 5.2 volts along with the regular standby voltages, all the others remained at 0 volts. I only had a 1/4 watt resistor, couldn't find a 1/2 watt.
                  Pins
                  8 - 5.2
                  15 - 5.2
                  22 - 20.4
                  • Toasty
                    • Jul 2007
                    • 4171
                    #29
                    Umm, please indicate what those pins mean...?
                    What value resistor did you use?
                    veritas odium parit
                    • torgeson5kqs
                      • Mar 2011
                      • 116
                      #30
                      Pins on the output connector where you asked me to monitor the voltages.
                      • torgeson5kqs
                        • Mar 2011
                        • 116
                        #31
                        resistor was 56 Ohm's
                        • Toasty
                          • Jul 2007
                          • 4171
                          #32
                          I have no idea what those pins mean (nor does anyone else) without pulling out the sheet and looking it up.
                          Please tell me what voltage is supposed to be on each one.
                          If I understand you correctly, 3.3/5/12 were -ALL- zero (and stayed there) with the supply jumpered from output negative thru the resistor to M3 Pin 2? Correct?
                          56Ω is good.
                          veritas odium parit
                          • torgeson5kqs
                            • Mar 2011
                            • 116
                            #33
                            Sorry I don't know how else to show you what I meant, the correct values are shown below. Pin 22 should be 24v but it seems to be anywhere from 20 to 24 volts either when in standby or when on.
                            Pin / Correct Volts / Actual Volts
                            pin 8 / 5.1v / 5.2v
                            pin 15 / 5.1v / 5.2v
                            pin 22 / 24v / 20.4v
                            • Toasty
                              • Jul 2007
                              • 4171
                              #34
                              The 20.4v is correct until the secondary voltages come up. Then it will be ~24v.
                              5.1v or 5.2v is fine.
                              Again:
                              They didn't jump or even attempt to come on? That is -very- odd.
                              veritas odium parit
                              • torgeson5kqs
                                • Mar 2011
                                • 116
                                #35
                                Yes, that is correct. there was no jump on the meter at all, I'll try again tonight with another identical power supple that is also in need of repair to see if I get similar values and report back to you.
                                • torgeson5kqs
                                  • Mar 2011
                                  • 116
                                  #36
                                  I went ahead and tried again tonight to get voltages on another power supply. It's almost like you need 3 hands to do this. The only alligator clips I have are all attached to test equipment. So I had fiddle with it. Anyway now I'm not even sure I'm doing this right. I've attached a pictures with the resistor on the underside of the board to better show what I've done. Again, I'm not confident I'm following your instructions correctly. On the opto for M3 (underside) is pin 1 (square) the negative output and you short it with pin 2 using the resistor? If thats the case I'm not getting any voltages at other than the ones I gave you in the previous post. Those previous voltages I gave you are from standby regardless if I do anything with the opto.
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #37
                                    >>Connect a jumper wire (alligator clips) from output negative to one leg of the resistor.<<
                                    Means: the output of the power supply negative terminal(s).
                                    You could also solder one end of the resistor right to the negative which is 3/4" to the left of M3 / D1. The copper heatsink (on top) to the left is negative and you can see where the 2 feet for it come thru the board and are soldered in. Any trace on that will do.
                                    veritas odium parit
                                    • torgeson5kqs
                                      • Mar 2011
                                      • 116
                                      #38
                                      Ok I finally got some time to try this again and soldering the resistor to the feet of copper heatsink really helps. I was able to get voltages on another similar PSU but the layout is slightly different. However, on the PSU in question I still have no voltages coming out. They are all zero except for the ones that are the standby voltages which I mentioned in a previous post.
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #39
                                        Ok. I'll check some other voltages and get back to you. Might be a bad M3.
                                        veritas odium parit
                                        • Andy3665
                                          #40
                                          Have you checked to see if there is a short in the power factor controller in the primary side. I've found about 10% of these have a blown PFC chip.
                                          Also I found in some cases, that the 3.3V rail is pulled low. It appears the housekeeping circuit uses this as a reference voltage and the PSU increases the output, but by doing so over volts the 5v and 12v rails, which get detected and then the PSU instantly shuts down. This all happens in a split second, but can be viewed using a digital storage scope.
                                          • ryogadan78
                                            iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                            by ryogadan78
                                            Hi guys, I need your help again.
                                            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                            06-10-2025, 03:49 AM
                                          • Stephen
                                            iMac M1 DFU restore issue
                                            by Stephen
                                            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                            this is the message it gives me with the error
                                            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                            03-07-2025, 12:19 PM
                                          • Stephen
                                            iMac 27” 2020 Boot issue
                                            by Stephen
                                            Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                            08-16-2024, 09:32 AM
                                          • tommy97
                                            iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                            by tommy97
                                            we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                            Any ideas what might've...
                                            04-20-2024, 04:48 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
