Seasonic Gutless fan fix?
  • bigbeark
    • Jan 2010
    • 661
    I have a Seasonic PSU with APFC and the fan hardly turns, resulting in hot air coming out of the PSU exhaust. I've google this and it seems a common problem.
    If I could get the fan going a little faster, I'm sure a cooler PSU would result.
    I suspect the fan speed is triggered by some thermistor that's not working properly.
    Since the PSU is otherwise fine, couldn't I just reroute the fan wires to one of those fan speed controllers that I see on Ebay?
    The PSU was $100+ retail and I don't want it to fry itself.
    Ideas and comments welcome!
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Seasonic Gutless fan fix?
    Put it right across +12, so it runs 'full blast.' When you have the unit apart, it would also be the perfect time to oil the fan.
    Edit: Get rid of any craps in there as well.
    -Paul
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • mockingbird
      • Dec 2008
      • 5488
      12V is too loud. It will sound like a jet engine. You need something between 5V and 9V.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Depends on the fan. I have fans where their rated 12v means "doesn't turn much at all".
        A working TV? How boring!
        • c_hegge
          • Sep 2009
          • 5219
          I sometimes make up my own temperature controllers with a trimmer pot, so you can adjust the target temparature.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            The fan could very well be bad, and is only turning when the thermistor tells it to "ramp up" the speed. I have a FSP PSU that's like this. At the lower "cool" voltage, the fan is stalled, and will only start turning when the PSU gets good and hot.
            Ludicrous gibs!
            • everell
              • Jan 2009
              • 1514
              I have a fan like that on the computer I use as a flight simulator. The fan ramping up like a jet engine gives the flight simulator added sound effects!
              Besides, this fan is cooling an Antec True Power 400 watt power supply....it needs all the cool air it can get! With new capacitors and cool air blowing, it sounds much better than the PowMax 400 that was originally in it!!!!!
              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              • c_hegge
                • Sep 2009
                • 5219
                My PSU load tester has two Delta fans rated at 252 CFM each, so that's over 500CFM in total. It sounds A LOT like a boeing 727.
                • mockingbird
                  • Dec 2008
                  • 5488
                  Come and duel with me on BF Desert Combat El Alamein. You can have the American planes. I will shoot you down with that Arabic MIG using only my mouse and keyboard.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    You could move the thermistor to something which becomes hotter (temperature probe helps)
                    NOTE THAT THE PSU PRIMARY HEATSINK SITS AT LIVE VOLTAGE SO DO NOT TOUCH IT WITH PSU RUNNING!!!!!!!
                    Good candidate for hotter than secondary side heatsink is primary side (but technically more dangerous)
                    The secondary side coils can get very warm too....
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      If you can stick the thermistor on the inside of the secondary coil then you're all set. I strongly recommend against moving it to the primary side - not only will you compromise safety if the heatsink is live (some are, some aren't), but you will also disturb the control circuit.
                      The primary heatsink is either floating or connected to the primary DC bus negative for a reason - if it were connected to ground, all the interference generated by the switching transistors would go into the ground and disturb all equipment sharing the same ground bus.
                        master hoarder
                        • May 2008
                        • 12175
                        Find the thermistor for the fan controller and see it's PTC or NTC. If it's PTC, add a resistor in series with the thermistor. If it's a NTC thermistor, add a resistor in parallel with the thermistor. As for what value you should use for the resistor - well, that will take some experimentation. Probably a good idea to hook a potentiometer and play around with it until you get desired results.
                        Prior to doing all of this work, though, I suggest you check the fan and make sure it spins easily and is not starting to seize up.
                        Or if this seems like too much work, just change the fan with one rated for higher CFM.
