Recommend primary capacitor ratings
  • japlytic
    • Oct 2005
    • 2086
    Here are some values I recommend for the two 200V/250V primary capacitors used in most PC power supplies, board space permitting:
    <200W: 220uF
    200-250W: 330uF
    251W-350W: 470uF
    351-400W: 680uF
    401W-450W: 820uF
    451-550W: 1000uF
    551-650W: 1200uF
    651-750W: 1500uF
    751-850W: 1800uF
    851W-1000W: 2200uF
    Some of these have been overrated, especially at the higher wattage end.
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Recommend primary capacitor ratings
    Some values I've seen:
    220uF: 90W Gateway/Newton, 250W cheapo (PC P&C's prime example of a bad PSU)
    470uF: 200W Dell/Delta, 550W Q-tec
    680uF: 300W Antec & Fortron/Sparkle, 350W Enermax
    820uF: 300W Delta (oddly, rated for down to 100VAC, not the usual 90VAC)
    1000uF: 350W Fortron/Sparkle
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Well, here my question comes again then ;-)
      Can someone more knowledgeable than me please comment on the very small rating of the Primary bulk cap, only 270uF in the S12 430w PSU, and 220uF in the 350w Seasonic?
      Is it due to the active PFC or something? I mean I've seen Primary caps in L&C powersupplies with almost twice the farad rating!!!
      • Oklahoma Wolf
        • Dec 2005
        • 353
        It's the active PFC I'm sure. My FSP 600W with active PFC has a single 470uf 400v Capxon on the primary side, while the older 530W with no PFC has two Teapo 1200uf 200v capacitors.
        • Chris1992
          • Apr 2005
          • 561
          Which would explain the Q-tec's abnormally low primary cap.
          The great capacitor showdown!
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Per, there are two factors involved.
            First, in P/Ss without active PFC, the two I/P lytics are connected in series (necessary for the I/P voltage range switch). This means that the net capacitance is cut in half. IOW, if you have two 470uF lytics, the net capacitance is 235uF.
            Second, when you have active PFC, the voltage on the lytic is typically in the 325V-350V range (and regulated). Without PFC, the voltage across the I/P lytics is typically in the 260V-270V range (unregulated). The formula to calculate the energy stored in the lytics is .5(C)(V^2). Thus, for the same net capacitance, if the PFC bus voltage is only 325V and the non-PFC bus voltage is 265V, the lytic in the PFC is storing ~50% more energy.
            PeteS in CA
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Thanks for the explanation Pete, I really appreciate it!
              • Oklahoma Wolf
                • Dec 2005
                • 353
                Me too
                Just remembered something about my 530W - next to the two 1200uf Teapos, there is a place for a PFC board... I wonder how much that would have affected Fortron's choice of input capacitors had the PFC circuitry been added. Then again, now that I think about it, that may just have been a soldering point for a passive PFC coil...
                • jonnyGURU
                  • Feb 2006
                  • 244
                  An SMPS I know told me pretty much the same thing OP is posting. He said that 1000uF in a 500W and 1500uF in a 550W is widely accepted, but said that it's more "accepted" to use a 1500uF in a 600W.
                  Of course, that doesn't take into account the 470uF~820uF caps found in 500W and up active PFC PSU's.
                  Rest in peace BFG. You were... a job...
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    I have a Topower server PSU that's supposed to be 420w... has two CapXon 1200uf 200v primary caps...
                    Ludicrous gibs!
                    • MORETTIGIAN
                      Capacitor detached from PCB – RTX 2070 Super Founders Edition
                      by MORETTIGIAN
                      Title:
                      Description:
                      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                      I did not notice it detaching, so I am unsure of its original location on the PCB.
                      Procedure performed:
                      - Removed backplate
                      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                      - Reapplied thermal compound
                      - Reassembled card
                      Observed behavior after reassembly:
                      - GPU powers on and operates normally under...
                      09-18-2025, 12:14 PM
                    • Prolog
                      RTX 3080 FE Identifying capacitor
                      by Prolog
                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                      I hope these photos make it clear which component I am referring to:
                      (yes, the soldering is a bit botched from removing the blown one, I know)
                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                      12-01-2024, 08:27 PM
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                    • chth96
                      How can I test non-polarized capacitor?
                      by chth96
                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                      06-02-2024, 07:31 PM
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
