Willawake says : Sorry dood, i edit your post to say that this is the discussion about the psu pictorial thread. if you want to say it, please say it here.
Power supply build quality pictorial DISCUSSION
This is a sticky topic.
Re: Power supply build quality pictorial
Originally posted by japlyticABS-6G76 satellite receiver
MDS STB3110 satellite receiver
Topfield TFPVR5000t
I have had a Topfield TFPVR5000t since March04. (The Toppy is the best toy EVER, IMHO)
What is your opinion of the PSU and the caps on it, and the caps on the main board for that matter?
I notice alot of them are "Sam Young", while the big one is a "Sam Wha".
I open it up regularly for HD removal/quick-transfer (I've got a WD250 in it) and do a quick visual inspection of the caps each time, just for safe measure.Last edited by willawake; 01-07-2006, 05:17 PM.
I open it up regularly for HD removal/quick-transfer (I've got a WD250 in it) and do a quick visual inspection of the caps each time, just for safe measure.Last edited by willawake; 01-07-2006, 05:18 PM.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
my 250W Channel Well CWT-250ATX is approximately 12 years old. This PSU is so old, the 92mm fan blows into the computer case instead of into the PSU.
Primary caps are 470uf Matsushita, secondary side is a forest of Fuhjyyu... not one appears bad. This PSU was in regular use up until a month ago.Last edited by willawake; 01-07-2006, 05:21 PM.
I guess '98 would be about right - I only got that unit and a 10gb IMB hard drive a year ago in exchange for a Fujitsu 6.4gb hard drive. It belonged to a friend, who bought the case it came in well before I'd even met him.
As it turned out, the IBM was DOA so I'm not sure I got the better part of that bargain
Notice the nice substantial heatsinks on the Deltas (and O/P trannies) and the Sparkle? Ya gotta keep the junction temps on those O/P rectifiers and power MOSFETS (possibly power transistors in the Sparkle) within reason. The power ratings are real on those.PeteS in CA
Originally posted by doodDid you also notice what appears to be a large burnt spot on the above Sparkle?
Yes, I did see that. It looks like a 1W or (more likely) 2W. It could be disspating its rated power or a bit more, or it may simply be mounted too close to the PCB. Normal design practice at places I've worked at was to mount resistors 1/2W and higher spaced off the PCB to avoid scorching the board. Good design practice would be to use resistors at ~70% or less than their reated power (taking into account the operating ambient temp. US mil-spec requires 50% max.PeteS in CA
Originally posted by Per HanssonL&C DR-A300ATX, 300w, +5v 30a, +12v 10a, +3.3v 20a. +5v & +3.3v 160w max. 470uf VIVA primaries, secondary side Jun Fu & Rulycon, 2 caps and fan missing due to started recap work...
You're going to recap an L&C?
Since there is no ugly integrated-into-PSU-case fan grill on that, does it use a removable wire fan grill?
Please post the after-the-recap photo of that L&C after you recap it.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
I already recapped it, See here...
The missing fan was because I put a 92mm fan in the bottom of the PSU instead, to reduce noise. And because the 80mm one started to fail and I had a 92mm one just on my bench
That PSU came from a real cheap case, has powered a friends comp a few months before he got a real PSU, and after that my brothers till the caps failed and it would no longer turn on..."The one who says it cannot be done should never interrupt the one who is doing it."
FSP700-80GLC power supplies as research have shown are 700W power supplies.
Maybe they used the board for the FSP700-80GLC but changed the components?Last edited by willawake; 01-07-2006, 05:33 PM.My gaming PC:
The heatsinks in the 300W P/S are larger than the 400W? Puhlease! And there is no fring way those heatsinks in the "600W" unit are good for 600W continuous! 200W continuous might be pushing your luck.
PeteS in CA
I trust Fortron to rate their units more or less accurately - this one's supposedly 85% efficient, so the sinks wouldn't need to be quite as big as my maybe 65% efficient 530W with monster heatsinks. I've seen Tom's Hardware pull the full 700W from Aopen's version of the FSP700-80GLN too without issues. The sinks in that one are even smaller to allow the 120mm fan. Not sure about the 600W rating myself, but I am quite sure it'll do more than 200W.
Forgot to mention earlier that topmost sink is bolted to the case. I really need a digital camera
looks like my fsp300-60gt.
7 years of 24/7/365 and the yec caps are just starting to go.
not bulging or leaking.just more ripple than i like to see.wasnt causing a problem yet but i will recap anyway.found during a routine cleaning and pm .
confirms that bad qc may be the reason for bad caps.yec are well known crap but we have some here with lots of hard hours on them that are just now failing.
btw i see a few fsp psu on sale at 22.00.
i think the store ordered some so expect a full report :-)
Re: Power supply build quality pictorial DISCUSSION
Originally posted by Per HanssonEnermax EG365AX FMA, 353w, +5v 32a, +12v 26a, +3.3v 32a. +5v & +3.3v 185w max. 220uf Hitachi primary cap, secondary side Pce-Tur, no bulging after years of use...My gaming PC:
