I noticed in some power supplies the caps are glued together and glue to some other components. What do you recommend for this? Is there a brand or something. I didn't want to just pull out the hot glue gun.
what do you use to glue together caps
Re: what do you use to glue together caps
I usually use the gray RTV high temp stuff. A hot glue gun is also suitable.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Team : 49813
Join in!!
Team StatsComment
Actually it's in the last steps that it's applied.
IMO Its' purpose is twofold -
It keeps any oscillations from the choppers from being heard. The hissing and buzzing some folks can hear, a lot of times it comes from the coils and caps.
It also keeps the parts from moving during transport so they don't strike each other or the heat sink. The output coils have enough mass that striking the heatsink would badly damage them.
Toastveritas odium paritComment
in addition ... the "glue" also keeps the parts from vibrating and breaking off leads due to handling/shipping/normal use .
a fair a mount of mass on top of a couple of skinny legs that is free to move around is not a good thing .
think "pendulum" .
i use hot glue or silicone rubber (the acetic acid type) . a trade name is GE RTV type 1 .
the silicone rubber that smells a bit like ammonia is worthless in my book .Comment
not good for electronics.the right stuff smells like alcohol.
anything else can cause corrosion.
i still remember acetic acid crystals growing out of rtv on zenith tv tripler connections.
think "pendulum" .
yes ... i remember those too .
do you remember the zenith triplers that would last for 1-6 months and fail ?
they pulled them and did a re-design . as i recall they had a clip-on cover for some leads .
then there were those four lead white tubular "buffer caps" ... they made a smart move going to the sprauge "orange drop" style .
the electrolytic cap and resistor in the horizontal drive to the HOT was standard fair for replacement too .
you are correct about the acetic acid crystals ... the method i use is to apply a thin layer , up off the board and only on non-conductive areas of components ... not just blobbed on .
thorough curing is important .
i do not recommend it for very high voltage areas (multi-KV range) .
although properly cured , it is ok for rf work .
hitachi sent out their version of HV silicone rubber with each replacement kine for their projection sets .
it was used on the second anode connector .
the stuff had a very light ammonia-like smell to it . it was great !
it was not at all like the caulking compounds one finds at home depot .Comment
you can play it on the safe side and use the high temp hot glue .
the reason i mention the high temp hot glue sticks is that i "borrowed" a stick from my girlfriend's artsy-craftsy stuff ... the stuff was still soft and tacky 5 minutes after i applied it !
the method i use with the rtv can be a bit exacting for some people , but i have had good results over the years .
something that is bad to use is "contact cement" ... mitsubishi and a few others had some bad go-arounds with the stuff over the years .Comment
Most RTV nowadays is alcohol based the vinegar smelling stuff can still be bought but luckily the selection is slim. Even on the tube it says for 80s cars. I know the orange Permatex RTV is acetic acid based.
Permatex Gray or Black would work fine. I actually had to remove and apply the stuff on a 27" Panasonic TV I repaired in 09 I think. The main IC had it applied across the pins on one side. I guess it was to prevent arcing? It was basically the whole TV on one SMD chip.
It was gray like RTV to I reapplied gray RTV after I replaced the IC.
For caps I use hot glue especially when a cap is bent over or if it's a large top heavy bent over line cap. I put a little bed of hot glue underneath and push the cap down in it. Unlike silicone the cap will simply pull off with a bit of force should it need to be removed in the future.
Hot glue creates a solid but removable bond.Last edited by Krankshaft; 01-31-2011, 07:13 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
