what do you use to glue together caps
  • JOHNBOY
    • May 2010
    • 78
    I noticed in some power supplies the caps are glued together and glue to some other components. What do you recommend for this? Is there a brand or something. I didn't want to just pull out the hot glue gun.
  • Toasty
    • Jul 2007
    • 4171
    Re: what do you use to glue together caps
    Silicone caulk. Pick a favorite color and have at it.
    I'm partial to "Melon Green"
    veritas odium parit
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I usually use the gray RTV high temp stuff. A hot glue gun is also suitable.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Scenic
        o.O
        • Sep 2007
        • 2642
        isn't that glue stuff just there to hold the caps or whatever in place during manufacturing..?!
        PS: @ Topcat: your SAI2 dual Tuali board is up and running my NAS and other stuff
        • JOHNBOY
          • May 2010
          • 78
          In some cases it looks like it keep components apart from touching each other. I'll grab some high temp black RTV
          JB
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            That's super to hear!! It was sitting here collecting dust, hated to see it wasted. May it live long and prosper!
            Team : 49813
            Join in!!
            Team Stats
            • Toasty
              • Jul 2007
              • 4171
              isn't that glue stuff just there to hold the caps or whatever in place during manufacturing..?!<snip>
              Actually it's in the last steps that it's applied.
              IMO Its' purpose is twofold -
              It keeps any oscillations from the choppers from being heard. The hissing and buzzing some folks can hear, a lot of times it comes from the coils and caps.
              It also keeps the parts from moving during transport so they don't strike each other or the heat sink. The output coils have enough mass that striking the heatsink would badly damage them.
              Toast
              veritas odium parit
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                get the permatex ultra.it has an alcohol cure rather than acid.
                • CWB
                  • Jan 2011
                  • 34
                  in addition ... the "glue" also keeps the parts from vibrating and breaking off leads due to handling/shipping/normal use .
                  a fair a mount of mass on top of a couple of skinny legs that is free to move around is not a good thing .
                  think "pendulum" .
                  i use hot glue or silicone rubber (the acetic acid type) . a trade name is GE RTV type 1 .
                  the silicone rubber that smells a bit like ammonia is worthless in my book .
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    not good for electronics.the right stuff smells like alcohol.
                    anything else can cause corrosion.
                    i still remember acetic acid crystals growing out of rtv on zenith tv tripler connections.
                    think "pendulum" .
                    • CWB
                      • Jan 2011
                      • 34
                      yes ... i remember those too .
                      do you remember the zenith triplers that would last for 1-6 months and fail ?
                      they pulled them and did a re-design . as i recall they had a clip-on cover for some leads .
                      then there were those four lead white tubular "buffer caps" ... they made a smart move going to the sprauge "orange drop" style .
                      the electrolytic cap and resistor in the horizontal drive to the HOT was standard fair for replacement too .
                      you are correct about the acetic acid crystals ... the method i use is to apply a thin layer , up off the board and only on non-conductive areas of components ... not just blobbed on .
                      thorough curing is important .
                      i do not recommend it for very high voltage areas (multi-KV range) .
                      although properly cured , it is ok for rf work .
                      hitachi sent out their version of HV silicone rubber with each replacement kine for their projection sets .
                      it was used on the second anode connector .
                      the stuff had a very light ammonia-like smell to it . it was great !
                      it was not at all like the caulking compounds one finds at home depot .
                      • JOHNBOY
                        • May 2010
                        • 78
                        So what are you guys saying , the red high temp RTV is no good ?
                        • CWB
                          • Jan 2011
                          • 34
                          you can play it on the safe side and use the high temp hot glue .
                          the reason i mention the high temp hot glue sticks is that i "borrowed" a stick from my girlfriend's artsy-craftsy stuff ... the stuff was still soft and tacky 5 minutes after i applied it !
                          the method i use with the rtv can be a bit exacting for some people , but i have had good results over the years .
                          something that is bad to use is "contact cement" ... mitsubishi and a few others had some bad go-arounds with the stuff over the years .
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Most RTV nowadays is alcohol based the vinegar smelling stuff can still be bought but luckily the selection is slim. Even on the tube it says for 80s cars. I know the orange Permatex RTV is acetic acid based.
                            Permatex Gray or Black would work fine. I actually had to remove and apply the stuff on a 27" Panasonic TV I repaired in 09 I think. The main IC had it applied across the pins on one side. I guess it was to prevent arcing? It was basically the whole TV on one SMD chip.
                            It was gray like RTV to I reapplied gray RTV after I replaced the IC.
                            For caps I use hot glue especially when a cap is bent over or if it's a large top heavy bent over line cap. I put a little bed of hot glue underneath and push the cap down in it. Unlike silicone the cap will simply pull off with a bit of force should it need to be removed in the future.
                            Hot glue creates a solid but removable bond.
                              by momaka
                              03-12-2025, 03:42 PM
                            • eryjus
                              by eryjus
                              05-10-2023, 11:21 AM
                            • Paxman_Swede
                              by Paxman_Swede
                              Hello!
                              01-14-2025, 09:51 AM
                            • captain150
                              by captain150
                              03-16-2025, 07:34 PM
                            • Foetuss
                              Gigabyte GA-6OXT :: caps question
                              by Foetuss
                              Good evening
                              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                              But I was also suprised about the bigger boys, which are 330µF 25V.
                              Could it be they used 25V caps because they were cheaper / available at that time?...
                              02-11-2025, 12:22 PM
