I have a yuelin YLP-013 that I put together using some old parts (mostly parts pulled from other power supplies, 4A bridge rectifier, teapo caps, etc...) to use as a bench supply to power up various things. Problem is this thing crossloads like a bitch, and as soon as you get even a light load on only the 12v rail, the 5v and 3.3v go high and it shuts off.
Now because I will mostly be using the 12v rail I would like to disable the UVP and OVP for the 5v and 3.3v rails. Voltage regulation won't be too big of a deal as I won't be using it for powering electronics, mostly small motors and other things.
The PWM/protections IC is a EST7502B. On the data sheet, pins 1, 2 and 3 are labeled as the OVP and UVP pins for the 3.3v, 5v, and 12v respectively. Would one simply break the connection from these pins and their voltages?
