Power supply in plasma T.V
  • steveclark1983
    • 6
    Hi guys/girls,
    I'm totally new to the forum so I do hope this is posted in the right section. Apologies if not. Basically my issue is my samsung plasma tv. It started radomly turning itself off then getting stuck in an almost boot-up like cycle. Sometimes starting up then 2mins later restarting. After a bit of research on the net I've come to the conclusion it is highly likely to be the power supply board and quite possibly a bad capacitor. I've removed the back of the tv and located the power supply board. I'm trying to find which of the capacitors could be the issue. None of them show the tell tale signs in which you describe as a bad cap. The only one I can see that is different is one that has a green stain on the top (only small stain). I know this is mainly for p.c's on here but I'm guessing the boards work around the same basic principles. Any help would be much appreciated or just a shove in the right direction.
    Thanks in advance
    steve
  • mockingbird
    • Dec 2008
    • 5484
    Re: Power supply in plasma T.V
    I think the green stain is from a marker. What brand are the capacitors?
    • MixMasta
      • Feb 2006
      • 142
      Your best bet is to post some good photos to this forum of the board and anything else that looks suspect/interesting.
      • steveclark1983
        • 6
        from what i can see on the side CapXon
        • steveclark1983
          • 6
          ok I'll stick a of photos couple on of the board. thanks guys
          • steveclark1983
            • 6
            here is the best i could get as ive only the iphone to hand. 330.jpeg is the one with green on it. sorry for last post it made no sense whatsoever
            • mockingbird
              • Dec 2008
              • 5484
              CapXon...
              Eventhough they are not deformed or bulged if you will, replace them.
              Shame on Samsung for using CapXon. Darned Korean garbage.
              • steveclark1983
                • 6
                should i just replace the lot? Could you reccomend a decent brand to use? and finally does this sound like a possible cause to my problem?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4951
                  • New Zealand
                  Decent brands are listed in the FAQ section.
                  What you need to do however is make sure you get the ESR and Ripple Current rating correct.
                  What series are your CapXon? It should be written on them, two letters in capitals.
                  -David VanHorn
                  • steveclark1983
                    • 6
                    From what I can see the only letters visible are GL
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Originally posted by momaka
                      For CapXon KM use any of the following: United Chemicon LXY, LXZ, KY; Panasonic FC; Nichicon PW, PM, HE; Rubycon YXG
                      For CapXon GL: United Chemicon KY; Panasonic FK; Nichicon PM, HE; Rubycon PX
                      For CapXon KF: United Chemicon KZE; Panasonic FM; Nichicon HD; Rubycon ZL
                      Most of these are available on Mouser and Digikey. Rubycon ZL, PX, and YXG are available at badcaps.net only.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        1) It would help to know the model number of your Samsung.
                        2) Head over to the "Troubleshooting TVs and Video Sources" section and look for posts by PlainBill and Samsung plasma TVs. Pay particular to attention to the troubleshooting advice and techniques.
                        3) Find the service manual for your Samsung.
                        4) Take voltage readings and compare to service manual.
                        --- begin sig file ---
                        --- end sig file ---
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          by sam_sam_sam
                          07-01-2024, 06:34 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
                        • CMCM
                          Russound CA4 Power Supply Repair
                          by CMCM
                          Hello Everybody,
                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                          The outputs marked 12v and 20v are all measuring only 1v.
                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                          The capacitors physically look clean (no bludgesor leaks) and...
                          07-03-2025, 01:12 PM
