Spectroniq PLTV-3250 missing 5 volt
  • tjjc00
    • Dec 2010
    I have a Spectroniq PLTV-3250 that is missing the 5 volt side of the power supply. I was following a post by plain bill but never seen him again after the first few post any help please
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Spectroniq PLTV-3250 missing 5 volt
    If you search "PLTV-3250" on this site, there are 3 threads to give you some idea of what to check for and where to start.
    Also, this is better suited in the "Troubleshooting TVs and Video Sources " forum.
    --- begin sig file ---
    --- end sig file ---
    • ugamazing
      820-02020 PPBUS_AON missing
      by ugamazing
      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
      02-05-2025, 04:21 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
    • BYTEHAT248
      Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
      by BYTEHAT248
      Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
      11-14-2025, 04:48 PM
    • gurj1979
      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
      by gurj1979
      Hey guys.
      Need help with this one.
      Fan not spinning due to missing PWN Fan signal.
      Also 5 seconds from powering up it freezes, unless in BIOS.
      But as soon as Windows starts to load, it will freeze.
      CPU is COLD / Room temp when it freezes.
      I've replaced the CPU, same problem.
      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
      Replaced fan - same problem.
      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
      08-19-2024, 05:22 PM
    • salopian
      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
      by salopian
      Hello. I would need some advice please.
      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
      I have already replaced the logic board with another...
      02-27-2021, 07:30 AM
