Apevia WIN-500XSPX recap
  • Behemot
    • 4845
    • CZ
    Re: Apevia WIN-500XSPX recap
    That's most like it. Samxon has few mid to shit lines and than good lines. But lately I see also general purpose caps from japanese manufacturers failing, seems that they are not indistructable and can't handle when they are pushed over limit. I expect the same from Samxons GP caps.
    • cashkennedy
      • Aug 2011
      • 668
      So I took one of the 2 cx430 v2.3 that I recently bought out of the case to view the caps, and from what I can see through the grill / vent holes, its not even as good as samxon... its all crapxon except for the main DC cap, which is panny M series cap.
      I don't know any crapxon series' but I doubt it matters much, but if anyone cares of the 4 I saw 3 were green with gold writing, and one was the classic black with white writing that I replace 9/10 times I see any.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Probably KF and GF
        • Behemot
          • 4845
          • CZ
          They usually use Samxon GK/GF, both bad though cheap series. KM/GP for input. Don't understand that, Samxon has such great series like GT or RS…
          • Wrog
            • Oct 2009
            • 472
            Originally posted by cashkennedy
            Wrog replaced the shitty caps in his with samxon / pannys . Who knows what was there to begin with. If you read his original post he took the pictures after redoing all the caps except the last 2 that didn't have polarity markings.
            lol, I used this power supply as practice since it had been a long time with an iron in my hands. After reading the input here, I decided it wasn't worth the risk to actually use it. Ironically, I ended up putting a CX430 (recapped) in the HTPC and it's been running 24/7 for the last several years.
            Anyway, from my notes, here's what was in the Apevia at the time of replacing in case it helps someone:
            C103 Su'scon SL 470uF 200V 22x40 (47 max height)
            C104 Su'scon SL 470uF 200V 22x40
            C106 Jun Fu HK 1uF 50V 5x11
            C107 Jun Fu HK 1uF 50V 5x11
            C201 CapXon ?? 470uF 10V 8x12
            C203 Jun Fu HK 47uF 50V 7x11
            C204 Jun Fu HK 1uF 50V 5x11
            C205 CapXon KM 47uF 50V 5x11
            C206 CapXon KM 47uF 50V 5x11
            C208 CapXon KM 4.7uF 50V 5x11
            C210 Jun Fu HK 2.2uF 50V 5x11
            C212 Jun Fu HK 1uF 50V 5x11
            C213 CapXon KM 10uF 50V 5x11
            C303 CapXon KM 470uF 10V 8x12
            C306 CapXon KM 3300uF 10V 10x25
            C308 CapXon KM 3300uF 10V 10x25
            C309 CapXon KM 470uF 10V 8x12
            C318 Jun Fu HK 470uF 16V 8x14
            CapXon KM 2200uF 10V 10x20
            Jun Fu 2200uF 16V 15x20
            What crap, indeed.
            • Lobo
              • May 2010
              • 59
              #26
              Thanks guys, but I am doubting if my Apevia PSU would even be worth fixing. All that time and effort replacing caps, only to have some other crappy component fail later. Especially when an equally cheap replacement can be had on Ebay for $20.
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
                no-name Radeon 9600 XT recap and cooler
                by momaka
                I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                This one was actually suggested to me by ChaosLegionnaire....
                11-06-2020, 07:54 PM
              • Eh546
                Beginner, practicing to unsolder on a lead free xbox 360 board, it is hell.
                by Eh546
                Don't hesitate to tell me what i do wrong and if you have any tips and tricks, because i want to learn and improve.
                I have a 60w iron that can go up to 450c, cone tip, i usually set it at 400. I applied flux on solder, tinning the tip then applying new lead solder to the joint so that it can mix with the lead free and lower the melting point, then i tried to suck up the melted solder with the solder sucker. But that didn't work since the lead solder doesn't seems to mix with the lead free one. I also tried applying flux to a wick and the board, then tinning the tip of the iron and...
                05-24-2020, 06:59 PM
              • chj4591
                gddr5 ball lead?
                by chj4591
                gddr5 memory ball lead size?
                0.4mm 0.45mm 0.5mm​
                05-05-2025, 10:42 PM
              • Foetuss
                Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                by Foetuss
                Hi all
                Hope this is in the correct place.
                I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                Could use some double checking to see if I'm not doing something stupid .
                Pictures of the boards are attached.
                What I will be replacing with what : (planned)
                Soltek Golden ::
                4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                01-18-2025, 11:44 AM
