adjusting a 12V inverter to 24V
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8710
    Anyone hacked a 12V inverter for use at 24V?
    Wonder how much of a problem it is to do such. Other than the fan that seems to be a 12V unit that will need to be replaced with a 24V unit, as well as input filter capacitors that tend to be rated at 16 to 25V that will likely need to be increased to at least 35V, any other possible issues that need to be addressed?
    • 31286
    Re: adjusting a 12V inverter to 24V
    you probably need to look at the circuit,
    how does it power the control circuits? does it use a chip etc.
    • CapLeaker
      Leaking Member
      • 8352
      Never tried such a thing. But just thinking about it, I don’t think it is going to be simple.
      Besides the caps, what about the mosfets, transformers etc.?
      • petehall347
        • Jan 2015
        • 4450
        • United Kingdom
        looking at prices for new ones 12 and 24 are same price so guess they aren't too different inside
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8710
          I suppose I am targeting the chip based SMPS ones, and not the dumb inverters like the Heathkit MP-10 which are more problematic. hoping for a bit of a efficiency improvement - but more of just trying to sort of unify all electrical backup equipment without buying anything...
          • petehall347
            • Jan 2015
            • 4450
            • United Kingdom
            this should give you some clues .. https://www.youtube.com/watch?v=aPRSq-quzj8
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8710
              those old Heathkit MP-10 would require a transformer rewind, but hoping SMPS could just deal with it by changing duty cycle ...
              • CapLeaker
                Leaking Member
                • 8352
                I think you are going to be in for more than just the duty cycle and a few caps.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8710
                  Haven't tried pumping to 24V but I have a 300W inverter that I ran 18V.... fan was roaring (since it was a 12V unit) but at least it worked...
                  I don't know yet what happens if I tried upwards 32V... magic smoke release maybe...
                  • CapLeaker
                    Leaking Member
                    • 8352
                    Try it and let us know what happened. Lol
                    • eccerr0r
                      inverter H tree driver imbalance in an AC inverter
                      by eccerr0r
                      My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                      Yesterday, 12:34 PM
                    • ngml
                      Repair of an LG split AC system indoor unit PCB
                      by ngml
                      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                      This indicates an error in the communication between the outdoor and the indoor unit.
                      The outdoor unit is fine, so the problem is the indoor PCB.
                      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                      Does anybody have the schematics of this board,...
                      02-01-2025, 12:55 PM
                    • x_orange90_x
                      by x_orange90_x
                      01-29-2025, 09:24 PM
                    • CoinCoin88
                      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                      by CoinCoin88
                      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                      09-15-2025, 03:36 AM
                    • DrDos
                      Unit runs but no speaker output kenwood KR-6030
                      by DrDos
                      I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                      09-14-2025, 09:57 PM
