Wier WA505 SMPSU output failed
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 7977
    Re: Wier WA505 SMPSU output failed
    As long as these main input filter caps are within 20% of the rating, I don’t see it as a reason of what this PSU is doing right now.
      • 30919
      ZLK is nice
      • nath1977
        • Oct 2023
        • 23
        I think ive worked it out but not yet been able to try. There are remote sense outputs which I didn't connect when testing. Id imagine thats the problem!...
        This document prompted the thought. https://cdn.badcaps-static.com/pdfs/...06ef55eb63.pdf
        It seems like a plausible reason for the low voltage on the 5v, and based on some other reading, the auxiliary voltage outputs on PSU's tend to rely on the primary working properly and under some load.
        Every day is a school day.
        Will report back....
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 7977
          There are supposed to be shorting bars or jumpers installed. Even sez so. We had no idea that there are sens pins on the terminals.
            • 30919
            i hate sense inputs.
            if you get a poor connection the output ramps up until it hits a limit or you burn something!
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 7977
              That's probably why it went first place.
              • nath1977
                • Oct 2023
                • 23
                #27
                Hmmm joining the sense pins to the main output has made no difference to the voltage. ��
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 7977
                  On this PSU the you have to jump sense + to positive and sense - to negative. There should have been shortening bars that came with it. I guess either there is something wrong with the regulation / sense circuit if the shortening bars do nothing.
                    • 30919
                    maybe look for burned resistors.
                    a good example of why sense lines are a bitch is to search "atari ar2"
                    • nath1977
                      • Oct 2023
                      • 23
                      #30
                      My search continues…
                      I've sketched out the main components of the main output low voltage side and struggling to get a voltage reading across the transformer output prior to the rectifiers. Post rectifier diodes I get 3.5v, prior I get nothing. Will tidy my sketch and upload here. Any ideas?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 7977
                        Probably because your meter was still set in DC. You can’t send straight DC through a transformer. The rectifier diode is there for a reason on the output. Put your meter into AC mode and measure again.
                        • nath1977
                          • Oct 2023
                          • 23
                          #32
                          Thanks - I am aware I need AC setting though may have had a brain fade at the time. Will try later and use another meter too.
                          Here is a partly completed diagram https://www.digikey.co.uk/schemeit/p...5ca94532b4a1f0
                          The heavy duty busbars soldered on the component side are labelled and Ive added them to the diagram.
                          BB2 to BB7, 3.5vdc
                          BB2 to BB1, 0vac
                          BB2 to BB5 - need to check!
                          R205 looks like it might be the sense feedback.
                          Are T200 and T201 for measuring current as one side is a simple loop, and the other side has a lot of small windings.
                          T4 is the big planar? transformer with other outputs too.
                          There is a TH thermistor? fastened to the heatsink.
                          Will add more detail as I go.
                          • nath1977
                            • Oct 2023
                            • 23
                            #33
                            Re-tested and ensured I was on AC and tried a second DMM too. Nothing between BB1 and BB2. Resistance is 0.3 Ohms though it looks like some big fat metal plates, which if they had failed would have been pretty obvious.
                            BB2 to BB7 and BB2 to BB5 both read 3.5vdc.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 7977
                              Originally posted by nath1977
                              this link doesn't work for me.
                                • 30919
                                f that link - not putting up with at!
                                Scheme-it
                                The app is loading, please wait.
                                Initializing application...
                                • nath1977
                                  • Oct 2023
                                  • 23
                                  #36
                                  PDF copy...
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 7977
                                    BB2 to BB1 you may not be able to measure that AC with an DMM since it isn’t going 60Hz rather it’s going like 60KHz. Maybe try an oscilloscope?
                                    These type of power supplies are very complicated and probably my least favourite. Maybe there is something wrong with the feedback and something is higher in resistance than it should be?
                                    • FrancescoV
                                      Onkyo HT-R390 no sound output, video output ok
                                      by FrancescoV
                                      Good morning everyone,
                                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                      The firmware reported is the following:
                                      M:1.00/11107BLP
                                      D:?.??/????????
                                      O:1.00/11107AL
                                      The DSP firmware given the question marks seems corrupt.
                                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                      05-11-2025, 02:59 AM
                                    • jinu_j
                                      by jinu_j
                                      Hi
                                      05-03-2025, 10:51 PM
                                    • mikey5791
                                      by mikey5791
                                      Hi to all forum members,
                                      12-26-2024, 04:55 AM
                                    • MidnightRoller
                                      Can a resistor lose resistance after hot air?
                                      by MidnightRoller
                                      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                      02-02-2022, 11:46 PM
                                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                      by momaka
                                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                      09-19-2021, 08:44 PM
