Aeg Pover B 1000 UPS PCB problem
  • liniuks
    • Apr 2016
    • 15
    • Lietuva
    hi, i have Aeg Power B 1000 UPS. PCB Wont work. i removed pcb and have found a heated and burned component q30. the biggest problem is that, i cant read burned component label, because all front of component is burned out. could anyone help me know what component i need or have Aeg Power B 1000 schematic? I've attached ups, pcb and component photo. thank you.
  • CapLeaker
    Leaking Member
    • 8297
    Re: Aeg Pover B 1000 UPS PCB problem
    Take a bit of 99% rubbing alcohol, an old toothbrush and clean that old mosfet up. What PWM is driving the gate of the mosfet? If the mosfet is shorted to the gate, you also have to inspect the whole gate drive circuit including the PWM.
    • liniuks
      • Apr 2016
      • 15
      • Lietuva
      i think pwm is st 3843b and i see its body cracked too. i attach pwm photo. tootbrush and alcohol wont help, mosfet all front cover is burned at 1mm deep
      • CapLeaker
        Leaking Member
        • 8297
        Anything else in between the PWM and the mosfet?
        • ipn00tic
          Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
          by ipn00tic
          Hello everybody,
          I'm learning alone at home (with you) of course.
          I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
          The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
          I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
          The VCC_GT power...
          03-01-2024, 05:32 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Roll
          HP Pavilion X360 burned mosfet
          by Roll
          Hi, I have a HP Pavilion x360 - 15-dq0007nc (just about 26 months old) with burned mosfet. Sadly I didn't found any boardview or schematic for this model, so I need your help with this.
          The mosfet right next to it is probably SM3319NSQA N-channel.
          The burned one is connected to a Sic634 pin 8-11 "Power stage input voltage. Drain of high-side MOSFET" So it should be a P-channel? Can you help me with finding the right replacement?
          Also I measured about 15 ohms to the ground on the coil. But I didn't remove the burned stuff yet - it will wait until...
          05-28-2022, 05:12 AM
        • zwerw3
          High side mosfet of the power supply of the RTX2060 graphic chip burned out
          by zwerw3
          Hello. They brought a personal computer for repair in which the video card was GeForce RTX ™ 2060 WINDFORCE OC 6G (rev. 1.0). Graphics core power mosfet burned out.
          Is there a chance to restore the site where the mosfet was? I started to grind the mosfet substrate with a dremel, which stuck to the board, but for now I stopped and decided to ask you for advice. I also noticed dark spots on the PCB near the video memory chips. Does this mean that the video memory is out of order? I cleaned the place where there was a burnout, a short circuit of 12 V was removed. On the coils on the power...
          12-12-2022, 12:15 AM
        • bogosort
          Lenovo Slim 7 Pro X - Burned mosfet identification
          by bogosort
          I have a Slim 7 Pro with a burned mosfet. I tried searching online but cannot find anything. (I ended up on the Non-X schematics)
          Please see attached photos.
          It looks like it is written S2EGD on it.
          Thank you!...
          12-30-2023, 01:06 PM
