Acer vx5-591G I removed Mosfet and it works without it?! could it cause problem?
  • ipn00tic
    • Mar 2024
    • 7
    • Portugal
    Hello everybody,
    I'm learning alone at home (with you) of course.
    I have an Acer VX5-591G laptop that was given to me as scrap where I was training and diagnosing.
    The Laptop turns on and starts to boot for a few seconds but before displaying any image it short circuits the main 19V power supply and turns off.
    I managed to "repair" the laptop and it turns on and everything works, I even did game tests for the CPU and GPU and everything works but what I did was remove a Mosfet (PQ807) from the VCC_GT power supply.
    The VCC_GT power supply has two power lines (PQ807 and PQ809) and I removed the Mosfet from line 1 (PQ807).
    I replaced the Mosfet (PQ807) with a new one in good condition but it continues to short circuit, I removed the Mosfet (PQ807) again and it started working again without it.
    Is it safe to use the laptop normally without this MOSFET (PQ807) and only work with line 2 of the VCC_GT power supply or will I have future problems?
    Thanks​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    PU805 and PQ807 needs to be replaced together for it to work. The laptop will misbehave under load if PQ807 is removed.
    • ipn00tic
      • Mar 2024
      • 7
      • Portugal
      Thanks for your response.
      The Laptop also has a dedicated GTX1050 graphics operating, I think that all the graphics load will be directed to the Dedicated GPU and will never need extra power in the CPU graphics, what do you think?
      The Portable is for my personal use​
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        iGPU is needed even with machines with dedicated GPU. Recently had an acer nitro gaming laptop with horizontal stripes on display(It had GTX1060). It came after several service attempts where the screen was replaced/Edp cable was replaced and lastly GTX1060 was replaced. You know the solution was to replace SOC.It worked with perfect display after SOC replacement. this proves that igpu is needed even with machines on dedicated GPU. Rest is your choice. manufacturer dont put parts which are not needed-so imho,better to stick with the manufacturers design outlay.
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • mosfetratus
          VCCGT mosfet damaged igpu?
          by mosfetratus
          acer predator g9-791g, i had previous thread about short 19v, but i solved this problem by replacing mosfet, in fact both two phases, just as a precaution.
          Mosfet that went is responsible for phase B of VCCGT (iGPU) [u8004].
          [Schematics] https://www.badcaps.net/forum/showpo...75&postcount=6
          Damage?
          https://imgur.com/a/VoquX0n
          https://imgur.com/a/9UWjBLp
          can improperly soldered mosfet do this?
          https://cdn.badcaps-static.com/pdfs/...a40e178c24.pdf
          originally manufacturer...
          12-19-2021, 05:28 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • MicroSMD Lab
          ASUS ROG Zephyrus GPU Mosfet repeat failure
          by MicroSMD Lab
          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
