fsp atx-300pa good enough?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    im doing what is typical to oem companies. use a low-wattage, good quality power supply. why? because i feel like it!!!
    that said, will this 300w power supply be enough for thi system:
    -amd athlon 64 dualcore
    -2gb ddr2 ram
    -80gb sata hdd
    -geofrce 7600 pci-express
    -pci ethernet card
    -sata dvdrw
    -foppy drive
    -microatx mobo-is this ok???
    i think it will be fine. the 7600 card doesnt even use a 6pin connetor. its simply bus-powered, so im not too worried!
  • c_hegge
    • Sep 2009
    • 5219
    Re: fsp atx-300pa good enough?
    Can we have a picture of inside? Some of FSPs models are pure gutless wonders.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      /rolls eyes.
      i already put it in te case and put in the mobo. i have to remove the mobo to get the psu out. so no you cant get pics.
      but its a decent psu. i looked. but of course the usual crap caps!
      • c_hegge
        • Sep 2009
        • 5219
        A genuine 300W PSU should be enough, as long as it's nothing like this FSP
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          no- its way better than that piece of junk! wow i cant believe fsp even put their name on that shit. no this one has real heatsinks, an 80mm fan, and thermal control. but the caps are ost and teapo, but it has dual 470s on the primary side.
          that fsp you linked to reminds me of my okia 500w i blew up
          • c_hegge
            • Sep 2009
            • 5219
            OK then, it should be fine for that system then.
            • everell
              • Jan 2009
              • 1514
              Your power supply might be using the FSP3528 pwm chip. It might blow up your computer. But you can't replace the FSP3528 chip because it is a propriety remarked chip! You can't order them from Mouser or Digikey. So you have to be careful or your power supply might end up like this.....
              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                lol
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  lol. you are kidding about the fsp chip that will blow up my computer right?
                  • Toasty
                    • Jul 2007
                    • 4171
                    Ummm.... Mice ??
                    I had a mower whose ignition coil looked like that after they decided it was their winter home...
                    veritas odium parit
                    • everell
                      • Jan 2009
                      • 1514
                      More like "Mickey Mouse" power supply.
                      Here is a drawing of the FSP3528 chip from a Fortron with a huge black hole in the middle! As can be seen from this "modest" drawing, it is no wonder that your computer might blow up!!!
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Please everell. Are you kidding or not?
                        • everell
                          • Jan 2009
                          • 1514
                          Yes shovenose, the Fortron power supply with the FSP3528 that the drawing was made from DOES have a huge black hole in the middle of the circuit board.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            yes but is that chip liable to damage?
                            • everell
                              • Jan 2009
                              • 1514
                              Only the ones with an ion scoop
                              • BigTroll
                                • Sep 2010
                                • 1317
                                • LAMBDA SOND
                                I highly reccomend the HEC 250 SR-T, not only is it a worldwide famous power supply some might say its the power supply that saved america, i use it in my tiny case with a 3.4ghz Pentium 4 HT that runs OS X so i can run PowerPC games using Rosetta thus wasting resources and saving america.
                                My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  Umm. I think that was meant to sound outrageous thus being humorous, so I'll laugh about it.
                                  • BigTroll
                                    • Sep 2010
                                    • 1317
                                    • LAMBDA SOND
                                    its a real life story!!!!
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      @shovenose
                                      It has occurred to me that perhaps you did not understand what I meant by your fsp pwm chip having an ion ram scoop. See pictures below
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        whatever. its a perfectly good psu, and its being sold on craigslist
                                        http://sfbay.craigslist.org/nby/sys/2043093062.html
                                          Acer Predator PT516-51s-7600 Notebook Triton 500 SE Specification for Upgrade or Repair
                                          This specification for the Acer Predator PT516-51s-7600 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT516-51s-7600 boardview and PT516-51s-7600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-07-2024, 03:10 AM
                                        • irepair559
                                          Ps4 1215a hdmi diode readings good everything good but no pic??
                                          by irepair559
                                          PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                                          01-05-2023, 12:32 AM
                                          HP Z240 i5-7600 Specification for Upgrade or Repair
                                          This specification for the HP Z240 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 boardview and Z240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z240 is accurate, safe, error...
                                          09-12-2024, 03:44 PM
                                          HP Z240 Tower Workstation i5-7600 Specification for Upgrade or Repair
                                          This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          DELL Precision T3620 Precision 3000 i5-7600 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3620 boardview and Precision T3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:30 PM
