Help with Delta AP-396AM TV power supply
  • ravve
    • Jan 2023
    • 4
    • Sverige
    My Sony 85 inch TV from 2019 stopped working. Troubleshooted the error to the Power supply board, where the 3,3V standby voltage is completely missing.
    I am used to pinball repairs but never got into repairing power supplies.
    I would really love to fix this instead of bying a new board, but need some guidance.
    The power boad is a DELTA AP-P396AM GL93, (1-001-394-11).
    Any schematics would be great but I can't find any.
    What's done so far, with board removed from TV:
    Main fuse OK.
    Voltage over power cord connection (incoming) OK.
    Resistors OK.
    Most diodes including the zener diodes and some other components are testing short!
    Used a thermal camera and noticed a diode (nr1 in pic) that was significally hotter than the others. Removed that diode from circuit and indeed it tested short. Now the diode next to it didnt test short anymore, however it gives strange increasing values (at diode test with DMM, board not connected to power). I guess I'll go ahead and replace that diode as well.
    However, all other diodes etc are still testing short, which makes me think that more components are broken, am I right?
    Any help to where to go from here is appreciated, also schematics, video links.
    I am suspecting the IC DDA010 (number 2 in pic) as it also showed hot on the thermal camera. How do I test this IC? I know some ICs could be tested by diode test method? Tried to measure voltages at different components, like pin2 of the IC (Vcc in) but nothing...
    But really need help to know what to measure
  • R_J
    • 9633
    Re: Help with Delta AP-396AM TV power supply
    I'm not sure what you are using to test the diodes but it is not working, I would start by checking the voltage ACROSS each of the two small electrolytics near ic901 (C904, C907?) I cant make out the designation. One of them is the start cap which will have the vcc voltage for the ic.
    • ravve
      • Jan 2023
      • 4
      • Sverige
      Thanks! I'll check that out, but I need to forst replace the shorted diode I guess.
      Here's a video showing contuety testing beeping on mostly the small black (diods?) With locations marked with FBxxx. I'm sure there must be a short somewhere, or am I doing wrong? (The shorted diode is removed in the video):
      https://youtu.be/4yXOOKzcREk?si=yrFOSXkcoQzqg1dq
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        they dont appear to be diodes .
        • R_J
          • 9633
          You don't use BEEPS to check components, for semiconductor junctions use Diode test, for resistors use the resistance (ohm) scale
          • CapLeaker
            Leaking Member
            • 8352
            Also look at the voltage drop on the meter while you are in diode mode. Don’t use the beep / continuity function of your DMM to test components. Period.
            • ravve
              • Jan 2023
              • 4
              • Sverige
              Thanks everyone! So just to double and tripple-check what you are saying:
              These two babies shown in the pic ("GT3") aren´t these diodes? Because if I put the DMM in diode test mode, it tests short for both diodes. I´m pretty sure it should test like a normal diode, like ~0.5V in one direction and OL in the other direction. It simply shouldn´t show 0 ohms in continuety mode (beep), unless I´m doing something wrong here?
                • 31304
                looks like a GDT a gas discharge tube.
                is it across the transformer pins?
                • R_J
                  • 9633
                  I suggest looking at the trace (bottom) side of the board, you will see the GTx are across FLx coils (in this case the coils are basically a piece of wire)
                  Start by checking the Resistance of R915, If it checks open, ic901 will be bad as well
                  • R_J
                    • 9633
                    Are you sure you checked the correct pin, CN6401, pin5 for stby3.3v, (there are 28 pins) you can check the standby voltage on jumper wire J168 (located between HS5 and C120A)
                    • pcardoso73
                      iMac power supply short-circuit diode to ground
                      by pcardoso73
                      I have an iMac with the power supply reference: ADP-200DFB.
                      This power supply is not working and when trying to debug the problem with a multimeter, I found what I thought to be a short circuited diode (the short-circuit is to ground).
                      With the continuity test it beeps both ways, so doesn't block current flow at all then reverse biased. But after removing the diode the beep continues and the diode seems healthy. It seems to exist a real short-circuit.
                      As I have another ADP-200DFB power supply (faulty one as well), I have checked the same...
                      06-09-2020, 08:47 AM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                      This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 03:40 AM
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
