Misconceptions about ferrite cores
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I've seen a lot of posts mentioning "fake size 35 transformer" which can't be further away from the truth. What is referred to as the "real" size 35 is probably the EC-35.
    However, the 35 designator only refers to the width of the core. The ones you see marked as 35 but are smaller in height, like ERI-35 or ERL-35 or whatnot, aren't actually fake, they belong to a different series which is the ER-35. The even smaller ones are the EI-28 (on a side note, i've pulled two out of "350W" Powerlink supplies, now THAT'S a big fat lie), and here's the ubiquitous EI-33 which some of you refer to as the "size 33".
    Regardless of who made them, they will conform to the parameters in the Ferroxcube datasheets because they are standard parts. This is very useful if you want to build a SMPS for something else using parts from a PC power supply. So feel free to browse around their site if you need help identifying any unknown cores.
    A working TV? How boring!
  • paparazzo79
    Fake magsafe 2 charger
    by paparazzo79
    Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
    I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
    what to do?Should I use the fake one?
    Will it damage the macbook?...
    10-02-2024, 08:18 AM
  • Galraedia
    Fake Caps in Xbox 360
    by Galraedia
    I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
    02-04-2023, 09:55 PM
  • kingiii
    downloaded bios is smaller than the original bios dump
    by kingiii
    Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
    Thank you very much
    06-07-2025, 04:21 PM
  • mrkmpn
    Need help replacing blown ferrite inductor (I think)
    by mrkmpn
    After installing a replacement screen, the backlighting went out and I discovered what I initially thought was a blown fuse. I reconnected the cracked screen and bridged the "fuse" with tweezers and the backlight came on, so I tried the same thing with the replacement screen and the tweezers just sparked, no backlight came on, and the "fuse" was damaged even more. (And yes, the screens were the same model number. I have received an RMA for the screen already)
    The reason I think it was a ferrite inductor is that 1st, it didn't look like a fuse I'd seen before,...
    06-07-2022, 03:52 PM
  • eliemgh
    t470 have fake charging
    by eliemgh
    i have t470 have fake charging...
    09-14-2024, 06:11 AM
