Need help replacing blown ferrite inductor (I think)
  • mrkmpn
    • Apr 2022
    • 62
    After installing a replacement screen, the backlighting went out and I discovered what I initially thought was a blown fuse. I reconnected the cracked screen and bridged the "fuse" with tweezers and the backlight came on, so I tried the same thing with the replacement screen and the tweezers just sparked, no backlight came on, and the "fuse" was damaged even more. (And yes, the screens were the same model number. I have received an RMA for the screen already)
    The reason I think it was a ferrite inductor is that 1st, it didn't look like a fuse I'd seen before, and where it blew there was what looked like a ball of molten metal stuck to the side.
    Also, I found this post here where the user is referring to it as a ferrite inductor: https://www.badcaps.net/forum/showth...=GA401IV-BR9N6 , and the component this user is talking about is the same one I am dealing with. (going to pins 1 - 4 of the display connector) Right next to this component is a poly fuse.
    I also found another site, with a user having the same problem here: https://rog.asus.com/forum/showthrea...ark-fried-chip! , where another person with the same problem (but different model) found schematics for their board, and said this was their replacement: "Looks like in my case it's an SMD ferrite inductor (3A/120 Ohm/190 Henry/100 Hz/0603 series"
    Can anyone tell me if those specs this person listed could work in my case? Or what the possible ramifications would be of not getting the specific replacement? I haven't been able to find a boardview or schematics for this mobo, and the links I've posted here are the only things that have gotten me anything resembling a possible solution.
    Below is a picture of said component:
    https://www.badcaps.net/forum/attach...1&d=1654292173
    • 21841
    Re: Need help replacing blown ferrite inductor (I think)
    Whats the motherboard model/part number
    • mrkmpn
      • Apr 2022
      • 62
      Laptop model: GA40IV-BR9N6
      Mobo part number 60NR03F0-MB3220
      • Reintar
        Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
        by Reintar
        First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
        One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
        08-30-2024, 06:13 AM
      • swerg
        Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
        by swerg
        Hey everyone,
        I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
        I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
        I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
        06-06-2024, 03:39 PM
      • silver60618
        Blown Inductor on WD My Passport
        by silver60618
        Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
        Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
        Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
        Lastly am I correct in thinking there is no polarity on the smd component?
        Thanks!...
        04-05-2024, 09:54 AM
      • pjzz2000
        Blown Inductor - HP Envy 17 - J184NA
        by pjzz2000
        Hi
        Totally new to this website/forum, so apologies if not the appropriate place to ask, but.....
        I'm trying to diagnose my son's laptop motherboard.
        Power jack led on, power button led on, but I think post fails. CPU cold and no voltage around CPU graphics card.
        I start to suspect power rails, or PCH or CPU.
        I did a close visual check and find an inductor that looks in a sorry state, next to what I think might be the PCH. I can only see 2R2 I (or L), but from reading, this is not enough to identify the various specs required to get...
        01-28-2024, 10:39 AM
      • cmlewis89
        LG 47LB5DF blown power supply board
        by cmlewis89
        Hi folks,
        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
        09-03-2024, 07:50 PM
