ICE3B0365J Troubleshooting (W200 Sub)
  • SFB
    • Mar 2023
    • 48
    • United Kingdom
    Re: ICE3B0365J Troubleshooting (W200 Sub)
    Not looked at it for a few days so in the same situation as my last post. I need to find what isn't happy as it is obviously something intermittent. Going to reflow a few joints and double check the tracer repairs I had to do. I have freeze spray and an ESR meter now so more options if needed.
    Is it definitely bad caps on your board then?
    • SFB
      • Mar 2023
      • 48
      • United Kingdom
      Okay, I have got it working a few times now and it initially seems fine, can turn it on and off, play with switches etc. but after it is on about 15 mins once it gets hot it doesn't like it and then turning it back on results in flashing red light. Let it cool down and fine again so it definitely seems like a temperature issue and the 51ohm resistor and the mosfet heatsink get very hot.
      • R_J
        • 9607
        Do have the original resistor that was damaged? are you sure it was 51Ω and what type of resistor did you replace it with, it should not be a wire wound resistor. If it was just the outer coating that was crumbling the actual resistor was likely still good.
        Looking at the part number on the resistor it IS a wire wound resistor so you now have a coil in series with a capacitor across the transformer
        • CapLeaker
          Leaking Member
          • 8340
          Measure the voltage on both sides of the resistor until the unit clunks out.
          • SFB
            • Mar 2023
            • 48
            • United Kingdom
            Ahh, that might be it. The pictures sent over (attached) looked like a wire wound so that is what I told him to get. It supposed to be a metal oxide then?
            Would that cause the behaviour I'm getting then?
            I was thinking about getting a higher wattage one anyway with the amount of heat and the fact the old one had crumbled, so a 51ohm 7W metal oxide?
            Much appreciated
            • SFB
              • Mar 2023
              • 48
              • United Kingdom
              #26
              Actually, am I right in thinking that is a 7W wire wound? And there is a 5W in it...urgh
              • SFB
                • Mar 2023
                • 48
                • United Kingdom
                #27
                Will do. I think it is looking quite possible it is the cause especially if the wrong part is in there - I know it gets very hot anyway due to pictures of other boards.
                • R_J
                  • 9607
                  W7J does seem to point to a wire wound 7 watt 5% resistor, It just seems a bit odd to place a wire wound resistor in that part of the circuit but if that is what was there before it is likely ok.
                  That resistor and the capacitor in series is the snubber circuit
                  • CapLeaker
                    Leaking Member
                    • 8340
                    I’d say the original resistor was a 7w 51ohm resistor, just like rj identified. I just wonder why this amp is cutting out now. First I thought maybe the resistor is changing value during operation, but now I am not sure if the amp actually isn’t in over heat shutdown or something like that.
                    • SFB
                      • Mar 2023
                      • 48
                      • United Kingdom
                      #30
                      So having a 5W in there is not going to be doing it any favours is it?
                      Will order a 7W and see if that helps. Kinda wish I had infrared goggles so could see if the heat is just focused around there. Not really used freezer spray before so don't feel spraying it on a live 330V circuit is the best idea.
                      • SFB
                        • Mar 2023
                        • 48
                        • United Kingdom
                        #31
                        This will sound like a noob question but I have a bunch of these 5W resistors - before ordering a bigger one could I run 2 in series in parallel with 2 others in series for 51ohm 20W just to test that this is the issue?
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #32
                          Yea you could but it's not going to be the issue: a 5W and 7W resistor is the same.
                          One is just physically bigger and by that able to dissipate a bit more heat via convection.
                          A smaller resistor can easily handle a higher than rated load as long as you cool it with forced air cooling.
                          • SFB
                            • Mar 2023
                            • 48
                            • United Kingdom
                            #33
                            Oh yeah, but seeing as heat seems to be what is causing the issue and with a 7W being the original component and having a 5W in now I am just wondering how much of an effect the extra heat dissipation will have. Grasping at straws really.
                            • R_J
                              • 9607
                              What happens to the voltages when this flashing happens? Do the standby voltages drop or does the main 54 volts to the amp board drop?
                              That 5 watt snubber resistor is not really going to effect the amp operation, it will get hot but so will a 7 watt
                              One component to check in the standby circuit is D2, sometimes it can short, it is across the 2.2Ω R20 so one end of the diode needs to be removed to check it.
                              It is also possible your problem is on the Amp board?
                              • SFB
                                • Mar 2023
                                • 48
                                • United Kingdom
                                #35
                                One of the 10kOhm resistors near that 5W had corrosion on a leg but tested okay - just took it out to check and the leg snapped so need to order a replacement for that before I can do anything else now.
                                • SFB
                                  • Mar 2023
                                  • 48
                                  • United Kingdom
                                  #36
                                  Will follow up on this once I have replaced that resistor, hopefully tomorrow.
                                  Before I got it working the whole of the secondary side was dead, and no idea what I did to get it working - I had just removed, tested, and resoldered a few parts. That D2 tested fine as did every other component in that area including the transformer, actually running out of things to test on that side of the board so was planning to just go systematically through the remaining parts just to rule them out. The fact the corroded leg of that resistor (R38) crumbled so easily makes me suspicious as it does get hot too.
                                  Once replaced I will set up a couple of multimeters and monitor both sets of voltages though, see what happens, and report back.
                                  I'll say it again, thanks everyone for your input with this, it is very much appreciated.
                                  • SFB
                                    • Mar 2023
                                    • 48
                                    • United Kingdom
                                    #37
                                    Right, resistor replaced but now I can't get it working at all, just blinking red light. I replaced a carbon resistor with metal, will that make a difference? Voltages on the startup and around the IC are jumping all over the place again. Whether I have the second board connected or not the only stable voltage on the board is the main DC up to the starter transformer.
                                    • SFB
                                      • Mar 2023
                                      • 48
                                      • United Kingdom
                                      #38
                                      Scratch that, I left it alone for an hour and it suddenly started working again...the behavior of this board has me baffled.
                                      Just left it with the volume up full (low input so as to not annoy the neighbours), after a few minutes it cut out went to flashing and then kicked back in again after a few seconds...going to leave it running and monitor it.
                                      • CapLeaker
                                        Leaking Member
                                        • 8340
                                        Something is intermittent somewhere. Weird. Try either heating or freezing certain components and applying some pressure?
                                        • SFB
                                          • Mar 2023
                                          • 48
                                          • United Kingdom
                                          #40
                                          Yeah, that is obviously why it has been so difficult to diagnose. I tried monitoring readings but once it goes all voltages on the board are effected so it's impossible to narrow it down. I left it on for an hour after the last post and it was fine. Off/on and red light flashing again but in a weird random morse-code like pattern which was new, flicked a few switches and came back on again. On/off again a bunch of times and was fine every time, so left it on for another half hour and occasionally it cut out and flashed red briefly but on for the most part.
                                          I will definitely try that again - I did poke around a bit when you last mentioned it but then it was just flashing constantly so at least now I can see if I can make it die by poking and heating/cooling. Bit worried about the moisture left by freeze spray on a live board though. Never used it before and don't want to fry anything...though at least it would be obvious what was wrong then haha
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • triplefour
                                            ONN 100012588 Has fluctuating Voltage on PSU 12v
                                            by triplefour
                                            Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                            anyway i go to this guys house to look at an ONN 100012588
                                            this is my first time looking at one of these brand of TV's.
                                            TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                            09-14-2022, 07:41 PM
                                          • blues_spirit
                                            practical courses for troubleshooting pc motherboards
                                            by blues_spirit
                                            Hello from France,
                                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                            Do you think this is feasible for me? I...
                                            12-18-2022, 12:56 PM
                                          • beetle1303
                                            Wine Chiller - SMPS issue - fluctuating voltages
                                            by beetle1303
                                            My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                            Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                            Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                            Checking further on the primary side: Incoming line input to bridge...
                                            09-04-2023, 10:33 AM
                                          • gcrezz
                                            GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
                                            by gcrezz
                                            The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
                                            07-25-2024, 09:49 AM
