Need help diode smd mark HS10 not fond
  • Gentian
    • Mar 2023
    • 19
    • Albania
    I have found in an inverter circuit 2 smd diodes number D88 and D89 with code HS10 on them. I tried searching and the smallest diode in the internet was HS11 U-fast 50V 1A. Found only HS11 TO HS18 from 50V to 1000V and 1A but nothing about HS10.
    Can anyone help me?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Need help diode smd mark HS10 not fond
    Maybe it says HS1Q?
    • lotas
      • Jan 2016
      • 4785
      • Russia
      Maybe it's "HS1G".
      • Gentian
        • Mar 2023
        • 19
        • Albania
        I tried but it looks more a zero or Q and not a G. HS1Q can't find also but HS1G it is 2A 400V.
        I am attaching also a photo of the inverter pcb where Diodes D87 and D88 are placed ( 2 burnet diodes HS10 a think they are marked). One of them is connected to ground where 4 parallel 2 Ohms resistor of the damaged Mosfet smps part of the circuit is damaged and burned also these to diodes. The other leg of the diodes goes in the middle layer of the board to 3 power multistage igbt modules. It looks that these diodes are some feedback from the igbt modules (AC Side). Igbt modules are ok and tested. Also I repaired the smps because the reason was a smaller Moset replaced original mosfet by somebody before and circuit has no fuse in that part so the damage was so violent. If anyone has experience with this kind of circuits what doides should they be? I switched the circuit and looks ok but these 2 diodes are not replaced although it is for sure that are burned?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Literally second result on Google:
          • Gentian
            • Mar 2023
            • 19
            • Albania
            Thank you very much. Definitely they should have these ratings because DC bus capacitors are rated 1200V DC.
            • asr
              Finding replacement diode iPad Pro 3rd gen A1701
              by asr
              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
              07-09-2024, 06:24 PM
            • unimatrix93
              TV backlight zener diode
              by unimatrix93
              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
              The led strips has 9 6V leds.
              02-10-2025, 12:13 PM
            • Baste
              MBR3045CT and SR3045LCT Schottky diode testing help.
              by Baste
              Hello experts,
              Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
              Aneng ST182 Meter.
              Diode mode.
              MBR3045CT:
              Diode mode
              Pin 2-1 - 0.150v
              Pin 2-3 - 0.150v ...
              10-21-2025, 06:14 AM
            • NicRac
              monowheel repair,Is the diode the problem?
              by NicRac
              Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
              First of all, I am new here. Therefore I will shortly introduce myself.
              I am Nico and currently I study Physics.
              In my freetime I like to build and repair stuff. Especially big battery's.
              A few years ago I got myself an electric unicycle, monowheel or however you call that.
              The battery bms was broken so I replaced and resolder that. Nothing big.
              I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
              07-26-2024, 06:13 AM
            • dennis_elx33
              NO BODY MARKING Diode
              by dennis_elx33
              Hello Everyone,
              I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
              While compared to the reading of another diode from the next channel it won't read at reverse bias.
              Now the problem is; it does not have any body marking.
              So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
              What do you think is this diode?
              Can you please suggest what part number can i use to replace this faulty diode instead?
              Hoping that you...
              06-14-2024, 12:36 AM
