Samsung ccfl tv powerboard clicks every 5 seconds.
  • CapLeaker
    Leaking Member
    • 8340
    Re: Samsung ccfl tv powerboard clicks every 5 seconds.
    Well… that would have been a nice find. Lol
    • CapLeaker
      Leaking Member
      • 8340
      Btw. Congrats to your 10k posts!
      • CapLeaker
        Leaking Member
        • 8340
        The resistor vid was a nice find, but I am afraid, that this TV doesn’t have any resistance like that on the PFC VCC pin.
          • 12307
          • U.S.
          #84
          Ok, looking straight at ICM801, the first pin on the inside has 384 volts, the middle pin on outside is 14.78 volts, I couldn't get to the middle back pin without touching the other front pins together with it so I didn't check that one.
            • 12307
            • U.S.
            #85
            Thanks, I guess I had a few quality posts along the way, wasted a lot of energy arguing with sad people, ignore button works for those types, if they get no response they will give up. I like helping more than working on my own junk, I don't know why but it seems easier to see whats wrong with with everything else but my own.
            • CapLeaker
              Leaking Member
              • 8340
              Check pin 4. If it has more than 6v the protection is on and she shuts down. If you are below that 6v threshold, I am calling this pwm fubar.
              • CapLeaker
                Leaking Member
                • 8340
                Maybe solder a small piece of wire to it.
                  • 12307
                  • U.S.
                  #88
                  Ok, can you tell which pin is 4? I think I'll need to get a microscope to see the numbers on that chip to look it up.
                    • 12307
                    • U.S.
                    #89
                    Ok, I'll try the wire, I could reach all but the middle back pin, unless that one isn't #4.
                    • CapLeaker
                      Leaking Member
                      • 8340
                      I hear ya, same here. I gave up on that too and making sure not to go down the spiral. Not worth my time, as I am very limited these days.
                      • CapLeaker
                        Leaking Member
                        • 8340
                        Look at the spec sheet. Pin one is the outer most and a bit separated pin.
                        • CapLeaker
                          Leaking Member
                          • 8340
                          And yes, I think the back middle pin as you call it is the one… maybe tap it somewhere else of the board.
                            • 12307
                            • U.S.
                            #93
                            I guess I could switch it out with the one on original board, I'll give it a shot, Thanks.
                            • CapLeaker
                              Leaking Member
                              • 8340
                              Easy to pick off the opto PCM801 pin 4. There is also a zener and a diode you could pick it from. Gonna hit the sack. Catch up again tomorrow.
                                • 12307
                                • U.S.
                                #95
                                I'll try it upside down.
                                  • 12307
                                  • U.S.
                                  #96
                                  Thanks, soldered a wire on, it's 15.5 and steady.
                                    • 12307
                                    • U.S.
                                    #97
                                    Ok, thanks a lot, I think there's hope for this one, glad I have the extra board for comparison and spare parts.
                                    • CapLeaker
                                      Leaking Member
                                      • 8340
                                      My bet is that on the optocouplers PCM801 and PCM802 the DCV on pin 1 and pin 2 compacted to secondary GND is nothing there. If there is nothing there, or the voltages are about the same, the opto is off and the FB pin 4 on the ICM801 PWM goes high and goes into overload protection and shuts down.
                                      You got to find that short!
                                      I suppose you could do something with the FB pin, not allowing the IC going into shut down. However I really don’t recommend that, as things get a bit unpredictable and the PWM wants to go full bore.
                                        • 12307
                                        • U.S.
                                        #99
                                        Ok, Thanks, I didn't know what those optos should measure, I tested them neg probe to hot ground, PCM801, pin 1 is 1.8v slightly fluctuating, pin 2 is 1.4v lightly flux, pin 3 is 0 volts, pin 4 is 14.6v. PCM802, pin 1 is 1.3v, pin 2 is 1.4v, pin 3 is 14v, pin 4 is 15v, looks like all the ones with the lower voltages like 1.3, 1.4 start about 1.8 or so then work down to 1.3 and stop. Did tests with powerboard jumped as stand alone. I guess the measurements from 1 and 2 to hot ground aren't helpful, I just tried them all while I was on hot ground, lol.
                                          • 12307
                                          • U.S.
                                          #100
                                          Ok my bad, I'll get the 1 and 2 pins measured to secondary/cold ground, ok only showing millivolts when using chassis ground for pins 1 and 2 of both optos.
                                            09-07-2024, 05:50 AM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
