Samsung ccfl tv powerboard clicks every 5 seconds.
  • nomoresonys
    • 12307
    • U.S.
    #101
    Re: Samsung ccfl tv powerboard clicks every 5 seconds.
    Wonder if one or both of those optos are bad, I could switch them out, not sure how to test them in circuit but I can test them out of circuit with a resistor and 2 meters.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      They aren’t bad. There is no voltage going there to light up the lil led inside. Same if the voltages are kind of equal.
      • nomoresonys
        • 12307
        • U.S.
        #103
        Ok, Thanks, was just checking ICS801 and pin 8 is ground and beeps back to primary ground/showing continuity as normal but pin 3 which is CS is also beeping back to primary ground, I think that is bad, both chips on both boards do it, I'm thinking they are both bad but not sure, the chip is there: https://www.google.com/search?client...bV3SosWCiznwRM
        • nomoresonys
          • 12307
          • U.S.
          #104
          Guess I could be wrong, just checked another powerboard which is not the same board but similar and it shows continuity from primary ground to pins 1 and 3.
          • nomoresonys
            • 12307
            • U.S.
            #105
            Traced it back and it looks like it does go to negative filter cap leg thru a resistor.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8340
              ICS801 pin 8 GND is tied to the main filter cap GND. I don't see any resistor you are talking about in the schematic.
              CS pin 3 goes through a resistor to GND and that is supposed to be like that.
              you really need to look at the PWM's data sheet. It will tell you what to expect on which pin and how for example the soft start works, how it starts and when it will shut down
              Something like this is hard to diagnose and twice as hard for me not sitting in front of it.
              Maybe do something like a sheet up and write down what you absolutely know, like boosted voltage, PWM chip, then the pins and pin names followed by the voltages on each pin etc.
              • nomoresonys
                • 12307
                • U.S.
                #107
                I'm probably not seeing something right, it looks like it runs thru RS803, CS803 and works down to neg. filter lead.
                • nomoresonys
                  • 12307
                  • U.S.
                  #108
                  https://www.shopjimmy.com/samsung-bn...w-605563813499
                  • nomoresonys
                    • 12307
                    • U.S.
                    #109
                    For sure, remote troubleshooting is tough, I'll look at the sheet for ICS801 again and measure those pins on standby and when jumped, maybe a clue will come, Thanks.
                    • nomoresonys
                      • 12307
                      • U.S.
                      #110
                      Giving up on this one, Thanks for helping, this old heavy relic just isn't worth all the effort, from what I read about this model it was kind of a lemon from the start, Thanks again.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8340
                        i guess we had at least a little fun!
                        • nomoresonys
                          • 12307
                          • U.S.
                          #112
                          For sure, I think I learned something, now if I could get my brain to remember what I learned, seems to go in and leak out a day or a week later lol, damn memory, reminds me of that movie with Drew Barrymore and Adam Sandler, where he has to play a video tape for her every morning because she can't remember what happened or what she learned yesterday.
                          • nomoresonys
                            • 12307
                            • U.S.
                            #113
                            Hello, I have a quick question, got this ch341a mini black to mess around with, have a suspect eeprom, wondering what is procedure. Do I need to try to freeze the eeprom before reading or just first try reading, can this thing fix a corrupt eeprom, I think it can or is it necessary to get a new one and try to program it? Thanks.
                            • nomoresonys
                              • 12307
                              • U.S.
                              #114
                              Will try to look it up, was just wondering about best practice for procedure.
                                09-07-2024, 05:50 AM
                              • eigma
                                Samsung UN40H5003 boot loop every ~8 seconds
                                by eigma
                                Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                Main board: BN94-07592P / BN97-08922R...
                                11-20-2024, 10:31 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
