Samsung ccfl tv powerboard clicks every 5 seconds.
    • 12307
    • U.S.
    #61
    Re: Samsung ccfl tv powerboard clicks every 5 seconds.
    I have not seen such a thing either, I'm totally baffled.
    • CapLeaker
      Leaking Member
      • 8340
      Well, once the PFC runns, all the secondary voltages should be up. Then enable BLon and DIM and Bob is your uncle. In this case, you got the PFC full bore, but nothing on the secondary? That goes against anything I’ve seen on these TV’s.
      • CapLeaker
        Leaking Member
        • 8340
        Check out ICM801 VCC
          • 12307
          • U.S.
          #64
          I think it's the middle outside pin, it's 14.73 volts. couldn't read the tiny print to look up the datasheet.
          • CapLeaker
            Leaking Member
            • 8340
            Not sure what the vcc PIN number is. But 14.73v should be good. I didn’t look up the data sheet.
              • 12307
              • U.S.
              #66
              I thought for sure it would be a resistor like in the video but can't find a bad one, each one that read off also read the same on the other board, like RI822 reading 54k on both boards but the resistor is marked 1003.
              • CapLeaker
                Leaking Member
                • 8340
                check the diodes in the secondary. I mean, WTF... this doesn't make sense.
                  • 12307
                  • U.S.
                  #68
                  DS804 is reading both ways, I'll try and throw a replacement in.
                    • 12307
                    • U.S.
                    #69
                    It reads 320 and ol off the board, but maybe 320 is just too low, switching it out, getting desperate, lol.
                      • 12307
                      • U.S.
                      #70
                      It's a rectifier schottky so 320 is prolly ok.
                        • 12307
                        • U.S.
                        #71
                        Switched it out with sb3200, no difference, I noticed that some of the surface mounted zener diodes on bottom of board are reading like 415 but they read the same on both boards.
                        • CapLeaker
                          Leaking Member
                          • 8340
                          0.3v drop for a Schottky is fine. Probe with your meter ACV right off the transformer on the secondary.
                            • 12307
                            • U.S.
                            #73
                            I use chassis for neg probe for that right?
                              • 12307
                              • U.S.
                              #74
                              Could only reach the outer pin on TM801, o volts ac, could only reach the left pin on TS801, o volts ac, else I would have to turn it upside down to check them all, that might work, can I get good readings like that, it would be ungrouded from chassis.
                              • CapLeaker
                                Leaking Member
                                • 8340
                                Nope, not chassis… across the winding on the transformer.
                                  • 12307
                                  • U.S.
                                  #76
                                  I could reach each end pin with the probes, on the primary side was 5 volts ac, on secondary was 0 volts ac.
                                    • 12307
                                    • U.S.
                                    #77
                                    Seems like it's not getting enough or any voltage.
                                    • CapLeaker
                                      Leaking Member
                                      • 8340
                                      So either the PWM ICM801 in the primary isn't starting for some reason or its bad. Check VCC pin 3 on it.
                                      https://cdn.badcaps-static.com/pdfs/...8f9905c079.pdf
                                      I've got weird experiences with this type of TO-220 package with 6 legs either playing dead or even a new one working for a few days then playing dead. Make sure these 6 legs and solders are hyper clean if you replace it. Did I already mention I hate those things?
                                        • 12307
                                        • U.S.
                                        #79
                                        Pin 7 is 14.6 volts, pin 3 is 9.2 millivolts, I hear that I don't like m either.
                                          • 12307
                                          • U.S.
                                          #80
                                          Oops I was measuring ICS801.
                                            09-07-2024, 05:50 AM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
