Please give me a schematic for Cooler master g750m
  • ceco87
    • Jun 2023
    • bulgaria
    on board i see
    e206420
    NE5000
    94v-o
    1448
    Thanks in advance
  • Uranium-235
    Scythe Fuma 3 or Cooler Master MA620M
    by Uranium-235
    I have a 5900x to replace my 5800x (actually a fair bit of performance difference). It came with the CM. I can't actually find any article of a direct comparison between the two. The Fuma has a Higher TDP but the CM looks to have a more solid build. Fresh AS5 either way.
    Scythe Fuma 3
    100.00%
    1
    0%
    0
    11-01-2025, 02:08 AM
  • anikin73
    Cooler Master 500W atx psu repair. Total cannot start at all
    by anikin73
    I am attempting to repair this. Circuit is quite simple, but i a quite stuck at it for a long time. so today i try to ask for new ideas. my challenge is to under stand what mistake i made. I had repaired not lesson than 50 pcs of various brands ATX psu . main pwm chip is Cm 6805 Sip 9 .
    5VSB is fine. When I short Pson, totally nothing happen. I check , the Cm 6805 VCC pin2 did have 16v, But totally nothing happen. I changed to a good chip from another good PSU. Same thing.
    What other pin should I check such that it will result in no start up at all ?
    07-07-2024, 07:06 AM
  • dariolana
    ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
    by dariolana
    Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
    Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
    02-26-2024, 07:47 PM
  • stomanata
    Problem with PSU Cooler Master MPX-5501-AMAAB
    by stomanata
    Happy new year.
    This PSU use WT7527V supervisor.
    On purple cable i have 5V, but on #4 of WT7527V i have 0.21V.
    If i try to start PSU with short between green and black it star for a second and stop.
    For what other to check? I now that is needed more info but i don`t know what else to share
    01-07-2024, 11:48 AM
  • tony359
    Cooler Master 1200W Silent Pro Gold - Bad power switch
    by tony359
    The PSU in question had a bad power switch. There was not physical feedback when switching on and - if memory serves - it was always ON even when in OFF position.
    I researched a bit and got some replacements.
    The replacement "got stuck" at first power up - as in "it's now always on".
    It looks like this PSU has a pretty large inrush current as my lights flicker when I turn it on with no load.
    Probably the switches I got are bad quality but I was wondering if someone could recommend a good replacement?...
    06-18-2023, 11:42 AM
