Cisco 2960-CX Not providing POE
  • fuxxy
    • 318
    First off, I'm sorry if this is the wrong subforum - None of the others seemed to fit the description.
    I've got this Cisco 2960-CX. It works flawlessly otherwise, but won't provide POE to the ports.
    On initial inspection, U4701 (An SI3458) has a physical hole in the die. I replaced with another chip out of a dead 2960, and it immediately popped a new hole.
    All I've been able to pull up are datasheets for mosfets, and I'm not quite convinced this is a simple FET.
    Popping the die implies an overcurrent downstream, correct?
    I have 3 more of these chips until I'm SOL. I've also attached the POE board from a 24-port switch for reference.
  • fuxxy
    • 318
    Re: Cisco 2960-CX Not providing POE
    Reference board from a Cisco WS-C2960X
      • 31304
      the mosfets are the 8pin parts on the left,
      thats the mosfet driver.
      one or more mosfets is shorted to the gate and is backfeeding high voltage to the driver chip
      • fuxxy
        • 318
        sweet, I can work with that. Let me do some testing...
        • fuxxy
          • 318
          Progress!
          Took my multimeter in basic continuity (beep mode), U4701 was the only FET that read short across source and drain. I'm a novice and can't find datasheets, so I'm interpreting source and drain as the two of the three larger sinked pads. These are 8-pin SMD FETs, with 4 pins bridged together, as well as 3 other pins bridged together. The last pin I'm assuming is the gate.
          I replaced U4701 (again) and Q4801 with similar components from my donor board. They're not quite exact, but appear to have the same footprint and family.
          SUCCESS! (Sort of...)
          When I initially received the switch, it would power on, boot, and respond to console commands. It just did not provide any POE, on any port.
          Now after this repair I'm getting POE power applied to ports 1, 6, 7 8. No POE PD device is being detected on ports 2,3,4,5.
          There's a small possibility that my donor U4701 is faulty. It makes sense to swap it out again for another chip, but this is quite the nerve-wracking experience. I'm afraid I'll overheat the board, POE controller, or both.
          I also noticed an error in my initial attempt to replace U4701 before I started this thread. The chip was installed in the wrong orientation - for others attempting this type of repair, the silkscreened dot on the IC die should line up with the beveled line on the PCB outline.
            • 31304
            work out which fet is for each port,
            then compare readings - maybe several are damaged
            • fuxxy
              • 318
              oh that sounds logical.
              I was thinking they used some weird setup like one fet for each side of the power pairs or something.
                • 31304
                i have no idea how it works
                just applying logic - i see lots of ports and lots of fets and a driver that can control them individually
                • fuxxy
                  • 318
                  As far as the source for each FET, all 8 of them have roughly -33v DC being supplied to each FET.
                  The drains, on the other hand, seems hit or miss. Q4803 & Q4804 are not "on" - fluctuating around 3v output voltage. This is with port 1 powering a POE device.
                  When I remove the device, nothing changes.
                  I'll replace Q4803 & Q4804 and see what happens.
                  • silberdrache
                    Burnt Hole under IC on MacBook Pro M1 Pro 14"
                    by silberdrache
                    I'm new to this Forum, so I hope it's the right place for this topic.
                    Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
                    I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
                    The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
                    I opened it up and there were only three drops of coffee...
                    11-10-2025, 11:19 AM
                  • 13mh13
                    Aluminum SMD caps vs thru hole caps (reliability)
                    by 13mh13
                    The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                    https://i.postimg.cc/kGrR6BpZ/image.jpg
                    I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                    I have not tested/replaced those alum. SMD electro PCB caps.
                    Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                    All the thru hole electros I removed / replaced on this CDP (and most...
                    04-05-2024, 07:41 PM
                  • LearningToRepair
                    How to correctly desolder through hole IC?
                    by LearningToRepair
                    Hi!
                    I tried to desolder through I had IC that I wanted to replace but failed. And now I came here to learn what's the correct way for doing this. I tried to use soldering wick but the capillary force kept solder in the hole. With soldering wick I only managed to remove the part of solder that was outside the hole. But the solder that was inside the hole never got out. And of course when I moved on to next pin the solder in previous hole hardened again so no matter how many times I did all the pins there was still solder in holes.
                    Question 1: what would have been correct...
                    07-19-2020, 04:01 PM
                  • madan1
                    cisco poe switch PSU issue
                    by madan1
                    Hello everyone.
                    I'm troubleshooting a cisco switch, which seems to have an issue with the PSU.
                    The psu has the following power rails - +12v, -53.5V and +3.3V
                    When connected to power, the +12 and -53.5 seem to work fine, but the +3.3 starts at ~3v and then goes down to ~0 (I guess this is the cap discharging). This happens both when the cable is connected and not to the switch board.
                    Any ideas what might be causing this behavior?
                    04-23-2024, 01:58 PM
                  • madan1
                    Cisco catalyst 2960c POE
                    by madan1
                    Hello everyone.
                    Got a catalyst 2960 from the usual scrapyard - ebay.
                    It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                    Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                    Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                    The switch fails to boot due to the following POST error:...
                    12-19-2024, 09:34 AM
