Dead PSU - HA33R4-058N, B1-058HA330, DC0-4905F20, 9-79-0361 (From AKAI MPC5000)
  • reessi
    • Jan 2016
    • 334
    The PSU was totally dead, the following parts were burnt O/C or SHORTED in the primary section:
    R14 -> R17 - Burnt O/C - 2.4 ohms,
    R18 -> Burnt O/C - 910 ohms,
    Q1 -> P7NK80ZFP - SHORTED,
    U1 -> PWM Controller UC3843B - SHORTED.
    I have ordered all the parts but there is also a Zener SHORTED and need help to know what to repace it with as no markings and the schematics are not available as far as I could find online.
    It is ZD1. I have attached pictures showing the location and drawn out the part of the circuit it is on...
    I would like to know it's function please as well as the other resistors and zener in the same path from the OUTPUT pin of the PWM to the MOSFET Q1.
    I have attached the datasheets for the PWM and MOSFET. The PWM datasheet states it can be connected directly to the MOSFET Gate yet it is not so an explanation of their functions would be great please.
    Also can the blown ZENER be omitted? Is it critical to functionality or some sort of protection for the PWM or MOSFET? My experience of zeners is only when used as a voltage regulator so I am not sure of their functions in this case.
    The pictures are off the internet as they are clearer than mine came out.
    Many thanks.
  • reessi
    • Jan 2016
    • 334
    Re: Dead PSU - HA33R4-058N, B1-058HA330, DC0-4905F20, 9-79-0361 (From AKAI MPC5000)
    I have noticed after doing the photos that D6, D5 & D3 on the internet photos I have used look like standard black diodes and are labeled D not ZD but on my PSU all of them are clear glass red ones looking like ZENERS just like ZD1, why might this be?
    Cheers
    • reessi
      • Jan 2016
      • 334
      Ignore the black arrow in one of the photos, it is just how it was from the internet!
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Glass type Zeners are the most difficult components to identify if you don't have a schematic . That's said , almost 99% of this type is colored according to a specific company . An example here , the yellow band color on DZ1 identify it as BZXXV , which means , it could be anything from 2.4 volts to xx volts , like e.g. BZX55V , which means in this case , it's a Zener Diode from the series BZX and it's 55v limit .
        There are other ways to identify the approximate voltages of such diodes , but it needs lots to explain , and in the negative side also , it won't help in anyway if the diode is burnt .
        • reessi
          • Jan 2016
          • 334
          Ok, any one know if it can be omitted? I can try powering it up via light bulb when the other parts arrive..
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            If I understand correctly the ZD1 zener also sits between gate and ground on the MOSFET?
            If so a sensible value is the 30v from the absolute maximums listed in its datasheet.
            That said the P7NK80ZFP MOSFET already has such a protection built in anyway.
            So it might be something left over if they previously used a different MOSFET without a zener protecting its gate...
            • reessi
              • Jan 2016
              • 334
              Yes that is correct. But there are 2 zeners with a paralleled resistor on each! This does not make sense to me, that is not how I have seen a zener used when being used as a voltage regulator?
              And the other zener has only a 10 ohm resistor paralleled so what can that be doing, seams like nothing!
              I mean obviously it does something so I would love to know!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8716
                Since you're using a protected mosfet, you can omit it, else if a regular mosfet you should use 12-15v or so, no more than 19V. The zener is there for...surprise surprise, protection...
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  The Zener does not have a series resistor, as such they are not voltage regulators in the traditional sense:
                  Because if the voltage and current rises too high it will just burn out, like it has here.
                  It is just intended to protect against voltage spikes, like a reverse diode against a relay coil.
                  When following the circuit you can just omit the zener: so you have a 10ohm resistor between the PWM chips output and the gate of the MOSFET, that's it.
                  Then you have a 22k resistor that makes sure it is pulled to ground incase the PWM output off state would not be off, this is technically also not necessary because it can't happen.
                  But I guess it would also offer some ESD protection when the device is off.
                  But again the choosen MOSFET has this already by built in Zener protections...
                  Since you have not drawn the direction of Diode D3 I can't tell you its purpose, because the band is not visible in the pictures.
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    If the Zener sits also between gate and ground on the MOSFET , like Per Hansson mentioned , then the Zener role here is simply protection and I think you told him that's correct . In fact , that's an Akai built and they're good on protection , a solid design I may say . Many modern systems ignore this function completely .
                    Otherwise , it would work like a voltage divider with a paralleled resistor , since it have its own internal resistance .
                    Anyway , in case you want to keep it , and using bulb lights , you can try different zener voltages since those are basically cheap .
                    • reessi
                      • Jan 2016
                      • 334
                      It's fixed! Many thanks for all the replies explaining it. I omitted the Zener to no ill effect.
                      • Nooy
                        VGA MOSfet permanently shorted and loss of MOSfet pad
                        by Nooy
                        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                        02-14-2024, 02:26 AM
                      • fallenapples
                        Acer Helios 300 N20C3- Dead Shorted mosfet blows
                        by fallenapples
                        Hey all
                        Have the above laptop which is shorting out the power supply. 19v when plugged into the wall then when inserted into the laptop ir reads nothing untill you remove it from the wall and plug it in again.
                        i found PQZ3 shorted so removed and confimed short gone.
                        replaced PQZ3 and it shorted again?
                        ive removed PQZ3 again and tested pads but theres no shorts there.
                        11-07-2023, 09:44 AM
                      • Dvsr
                        On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                        by Dvsr
                        Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                        I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                        After replacing the caps I started testing out the speaker. It seemed...
                        09-10-2025, 10:20 AM
                      • daemon123
                        MSI GTX-980ti shorted MOSFET on memory rail
                        by daemon123
                        Hi All,
                        I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                        What should be the next step. Kindly guide.
                        The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                        05-10-2023, 11:05 AM
                      • Jane
                        How do you test MOSFET in laptops ?
                        by Jane
                        I tried to use this method:
                        Testing an N-channel MOSFET:
                        Step 1: Discharge the Gate (turn off the MOSFET)
                        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                        Step 2: Charge the Gate (turn on the MOSFET)
                        Now, place the red probe on the Gate (G) and the black probe on the
                        09-27-2024, 03:31 AM
