(hipro) HP-D2808F3P
  • MXM
    • 430
    • Unknown
    (hipro) HP-D2808F3P
    Hello everybody
    This PSU came in a HP workstation xw4100, looks like the little board labeled "CTR BOARD" had some problems,
    https://www.badcaps.net/forum/attach...1&d=1282236762
    i have managed to look the caps values and resistances colors, but im having trouble with the SMD on the back.
    I believe is a transistor but, i am not sure, and if it is i dont know what is its part number... i was wondering if anyone has this particular model and could help me out by taking me a look...? please.
    Also, given the fact that i do not have around any other of this unit, i dont know if i could find the specific part even if known... so I began wondering what replacement could I use?? (if i cant get that specific) what should i be looking for in my dead PSUs cemetery? (cause i sure am I wont get new SMDs around)
    Any info, tip or advise is appreciated.
    peace.
    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
  • everell
    • Jan 2009
    • 1514
    Re: (hipro) HP-D2808F3P
    Looks like no one has a psu just like yours, but I have one that is similiar, probably an earlier model, the HiPro HP-D2537F3R.
    The resistor values are:
    R201 270k
    R202 240k
    R203 300k
    R204 300k
    The one I fixed, R201 and R203 were open
    The transistor is Q201, and the marking on it is BR (two other characters afterward I could not read, very tiny letters or symbols). It is a NPN transistor used to switch on the 5vsb pwm chip, a KA1H0165R.
    Voltages on Q201 when working properly are:
    emitter 24.4 volts
    base 25 volts
    collector 24.5 volts
    The capacitor I could not read the value of it without unsoldering and removing the small pc board from the main pc board. The capacitor also had glue all over it, making reading values near impossible.
    Hope this helps.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Use X-ray glasses or consult the voodoo woman that lives down by the river.
      Mann-Made Global Warming.
      - Dr Seuss
      • MXM
        • 430
        • Unknown
        lol pc...
        hey thanks everell ill try to get the best available of those
        haha first time ever posting from home
        • everell
          • Jan 2009
          • 1514
          I don't know the voodoo woman down by the river, so I will just continue using the voodoo3 in my computer to post comments on this forum and pester the cranky old man (pcbonez).
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Lol. I just got one of these PSUs if you're still looking for an answer...
            Didn't mean to dig up and old thread but this came up when I googled the model of the PSu and bad caps, because mine has a bulged Teapo...
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • rashidjafar
              Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
              by rashidjafar
              I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
              Values for :-
              PC43 : Capacitor [3x1.5mm]
              PL7 : Inductor [2x1mm]
              PC39 : Capacitor [1x0.5mm]
              Any ideas would be appreciated.
              I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
              08-07-2025, 05:10 PM
            • Kobok
              Different (lower) resistor values on PCB?
              by Kobok
              Dear Alls,
              For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
              09-19-2022, 07:30 AM
            • skdsp
              Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
              by skdsp
              I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
              Attached is the photo.
              Thank you!
              09-27-2025, 09:05 PM
            • magneh
              Behringer Eurolive B205D repair - help identifying transistor
              by magneh
              Hello
              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
              Still, I need to replace this transistor....
              06-18-2025, 02:34 AM
