820-02100 and 820-02382 bvr and sch files
  • Rashid36
    • Aug 2014
    • 59
    • Saudi Arabia
    • qazpoi12
      • Jan 2023
      • Russia
      Thank you very much and I bow low to you!
      • macabook
        • Sep 2024
        • 22
        • France
        THANKS
        • Pedro147
          • Sep 2016
          • 152
          Here is a re-upload of the files seeing as there was a data breach
          My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
          • ugamazing
            • Jun 2013
            • 164
            • usa
            I still get an error when trying to download them; anyone else able to download them? There may be some issues with file upload, or maybe they disabled it??
            piernov
            Admin
            SMDFlea
              • 20318
              piernov
              Admin
              SMDFlea
              Please give the admin time to sort out the issues, he`s trying his best
              • ugamazing
                • Jun 2013
                • 164
                • usa
                #27
                Thanks, Flea!! Had no idea there were still issues being worked on, thank you for the update! We appreciate you guys.
                • Pedro147
                  • Sep 2016
                  • 152
                  piernov
                  Admin
                  SMDFlea
                  there is nothing wrong with the upload and subsequent download
                    • 115468
                    #29
                    There was an issue with uploads. The server was launched from backup and upgraded os, php, and vbulletin. We just realised now the tmp upload directory and session directories changed. That is hopefully fixed. Still a few missing files.
                    • eccerr0r
                      by eccerr0r
                      Just want to post here:
                      Sorry for not adding anyone as "friends" ... unfortunately it's the same policy I have with fsckbook. No third parties need to know my acquaintances. If you're an acquaintance we both know it.
                      I don't post anything worth following anyway :-(
                      Note: If you're wondering why I post PDFs of homemade schematics, it's because I'm too lazy to convert to GIF as it requires effort to make sure you scale it to a size where all text is still readable.
                      BTW anyone trying to productize any of my schematic designs: Other than the obvious...
                      07-06-2019, 10:01 PM
                    • redoxy
                      Acer Nitro 5 N20C1 no power no charging
                      by redoxy
                      Laptop is not charging and not powering on.
                      Model details is AN515-55-517T
                      Board is FH51M LA-J871P
                      The circuit diagram and the boardview were generously posted by satishkumar.
                      I have tried following the Beginner's guide to laptop troubleshooting and started by taking measurements on the charging system.
                      I get 19V on the PQB3 MOSFET input and nothing on the output (pardon my ignorance of the proper terminologies)
                      Does this point to a bad MOSFET or could it be another component?
                      I have attached the charging diagram...
                      11-11-2022, 09:16 PM
                    • EasyGoing1
                      UPNP, "Standards" and hardware that implements it
                      by EasyGoing1
                      I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                      One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                      So I decided to implement UPNP...
                      07-16-2022, 07:12 PM
                    • Snownomow
                      Shock when touching power supply case (ACBel API1PC36 from PowerMac G4 MDD)
                      by Snownomow
                      Hello!
                      I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
                      I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into...
                      07-30-2020, 02:20 PM
                    • eccerr0r
                      LED modifications that have a warning...why?
                      by eccerr0r
                      Well it goes without saying but you shouldn't modify electronics at the risk of causing unintended consequences. However I saw an explicit warning to purchasers of an LED bulb saying this:
                      "Caution: Changes or modification not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment"
                      Then it goes on to say that it meets FCC part 15 rules, class B, which it should.
                      Now the question that the warning leads to... What modification are they talking about? What magical modification would...
                      10-26-2019, 08:56 PM
