820-02100 and 820-02382 bvr and sch files
Here is a re-upload of the files seeing as there was a data breachAttached Filesif you find these attachements useful please consider making a small donation to the site
My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SAComment
there is nothing wrong with the upload and subsequent downloadAttached Filesif you find these attachements useful please consider making a small donation to the site
There was an issue with uploads. The server was launched from backup and upgraded os, php, and vbulletin. We just realised now the tmp upload directory and session directories changed. That is hopefully fixed. Still a few missing files.User submitted datasheet, schematic, boardview, service manual, firmware, bios, & software.Comment
by plummmmI am trying to identify a potential missing component from an Asus X570-P motherboard. I could not find a boardview for that exact motherboard, but I did find one for the X570-Pro here https://www.badcaps.net/forum/troubl...prime-x570-pro
The component missing on my board I believe is a small 3 pin device above the Nuvoton Super IO. The X570-Pro uses a similar Nuvoton and there's a similar looking SMD just... -
by eccerr0rJust want to post here:
Sorry for not adding anyone as "friends" ... unfortunately it's the same policy I have with fsckbook. No third parties need to know my acquaintances. If you're an acquaintance we both know it.
I don't post anything worth following anyway :-(
Note: If you're wondering why I post PDFs of homemade schematics, it's because I'm too lazy to convert to GIF as it requires effort to make sure you scale it to a size where all text is still readable.
BTW anyone trying to productize any of my schematic designs: Other than the obvious...-
Channel: Visitor Messages
by redoxyLaptop is not charging and not powering on.
Model details is AN515-55-517T
Board is FH51M LA-J871P
The circuit diagram and the boardview were generously posted by satishkumar.
I have tried following the Beginner's guide to laptop troubleshooting and started by taking measurements on the charging system.
I get 19V on the PQB3 MOSFET input and nothing on the output (pardon my ignorance of the proper terminologies)
Does this point to a bad MOSFET or could it be another component?
I have attached the charging diagram... -
by EasyGoing1I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
So I decided to implement UPNP...-
Channel: Troubleshooting & Designing Networks
by SnownomowHello!
I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into... - Loading...
