iPad Air 4th Generation A2316
  • mon2
    • Dec 2019
    • 14847
    You can use 1k to 2k2 on these resistors which are very likely to be pull-ups as required by the I2C specification.
    See attached (from other ipad schematics)
    • Adambonz
      • Jan 2016
      • 13
      • France
      Hello mon2,
      thanks for your anwser, i don't speak english well but i try. Yes its very good idea and you have wright i go to change this resistor by another same like i2c line.But with zillion xzz i don't understand why have boardview but not schematics. its abnormal.
      Big thanks i go to test your way ans reply after. Have i nice week
      • Bonzadam
        • Apr 2022
        • 6
        • France
        Hello, I soldered 2 1k resistors it's true that on these lines there are 1k resistors except that it doesn't work. These are the resistors on the I2C gasgauge and SDA lines resistors near the battery connector of the 2 thin pins. The iPad Air 4 turns on and restarts alone, and stays on 0%.... I think battery has a problem too maybe...
        • claudioabbascia
          • Jun 2020
          • Italy
          have you the schematic of A2316 IPad Air 4?
          thanks so much I need the value of this capacitor.
          • mon2
            • Dec 2019
            • 14847
            Do not see a schematic in my database but only boardview file. The 2 caps in the same region are each linked to the PPVCC_MAIN_LCD_SW rail. You can study other available schematics to review which caps are present there and this board should be similar. These are bulk filter caps for the power rail.
            Suggest to source:
            10 uf, 6v3 rated or higher voltage 0402 X5R ceramic capacitor
            10 uf, 6v3 rated or higher voltage 0603 X5R ceramic capacitor
            0805 X5R ceramic capacitor
            Each should be low cost from Digikey / Mouser / Arrow / RS electronics. Grab a few of each since they are easy to lose when mounting. Only one will fit inside the PCB footprint. These caps are not polarized so no polarity to the mounting direction.
            • noipi
              • Aug 2017
              • 86
              • Singapore
              #26
              Hi all, where can i get the Schematic and boardview for this iPad Air 4th Generation A2316, or where can i have my subscrition? i really need this. Thank you for the answers.
            • GeirAndersen
              iPad .pcb file collection
              by GeirAndersen
              I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
              Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
              IPAD COLLECTION 1
              +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
              +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
              +---iPad mini3 820-00008(A1599) 820-00002(A1600)
              +---iPad mini4 820-00180(A1538) 820-00177(A1550)
              +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
              +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
              12-09-2024, 09:28 AM
            • Stephen
              iPad 9th generation Battery issue
              by Stephen
              iPad battery seemed defective, it would charge then once it turned on it wouldn't charge more. After ordering a battery it would charge then drain very quickly (1% drain every 20 seconds) it then wouldn't take a charge then take a charge when it hit a certain level. I'm assuming it is a defective battery, it doesn't turn off when unplugged but seems faulty. Sometimes when I plug it back in it doesn't even take a charge and keeps draining then all of a sudden it charges. Am I missing something?
              07-05-2023, 12:16 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • Aimbit
              Apple iPad Air 2 (A1566) - Seems to be power cycling, no display, new battery/Tristar
              by Aimbit
              Using an ammeter, original battery was only taking 90mA or so... then down to 0, up to 90mA, down to 0, etc, in a repeatable pattern. This iPad was very old, so first thing I did was swap the battery for a good one, and it came pre-charged. The old battery had negligible voltage.
              Now the iPad go up to about 1.5-1.6amps charge, then it drops to 0 after a few seconds... rinse/repeat as before. I tried changing the Tristar chip to see if that would help (and also my first real BGA chip!) but it seems to make no difference. Where should I look next?
              I should poke around the...
              06-29-2024, 09:51 PM
              Apple iPad 4th Generation 820-3249 Boardview and Schematic
              Apple iPad 4th Generation 820-3249 Boardview and Schematic...
              11-01-2024, 02:45 PM
