Need boardview, battery not charging
da0z8cmb8d0 rev d need boardview
Tags: None
Re: da0z8cmb8d0 rev d need boardview
We love boards that do not charge
This forum should be renamed to badchargers.net.
Do you have the schematic already ? Consider to post your same details in the laptop forum for feedback from techs.
Is the battery a known good battery ? Try another battery if possible.
Is the battery detected by the Windows operating system?
Start with a voltage measurement of each pin on the charger IC @ PU9 (BQ24737RGRR).
Also post each voltage on the battery connector so we can confirm if the SMBUS / I2C interface is working. -
Schematic + BoardviewAttached FilesPremium supporters get full download access and other benefits.
[QUOTE=SMDFlea;1152627]
Schematic + Boardview[/QU
THANKS YOU MASTERComment
DA0Z8CMB8D0 Rev.D 141118 Cad Display component informationAttached FilesPremium supporters get full download access and other benefits.
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by fixxxarHi badcaps community, Im very begginer guy which transitioning from IT into Tech industry due to finding it more logical in long-term.
Recently had my laptop broken.
Left 220v cord disconnected from power supply for 1hour and cameback - laptop was gone.
Drained bios, laptop started and then shutdown instantly. (battery showed 0%)
It did not turned on again. Checked one last time with unscrewed battery (wanted initially just replace the battery as it had only 50% capacity left.
That was my quick "diagnosing". And it slipped from my hands while... -
by ferah831208Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
- Loading...
