HP 242 G2 schematic
  • alviraph
    • Mar 2014
    • Philippines
    HP 242 G2 schematic
    Good Day! Please help I need hp 242 g2 schematic. Thanks.
    • 21853
    Re: HP 242 G2 schematic
    Post the motherboard model number
    https://www.badcaps.net/forum/showthread.php?t=88758
    1.1.3 Motherboard model number
    • alviraph
      • Mar 2014
      • Philippines
      Good Day Sir! Its 6050A2593401. Thanks
      • Dr Techno
        Motherboard Schematic and BoardView file for a AORUS 15P XC please
        by Dr Techno
        Hi Guys,
        I need a motherboard schematic for file for a AORUS 15P XC please. The EXACT motherboard is ga-rx5lxc rev2.0. It currently has a black screen issue and doesn't display to external display but boots into windows and can also display externally when running ubuntu. If anyone has a motherboard schematic file and boardview for this laptop it would be greatly appreciated. Thanks in advance!​
        05-01-2025, 01:45 PM
      • rddube
        Need help interpreting schematic of Lenovo B470 motherboard
        by rddube
        OK, so here is my issue.
        This Lenovo B470 motherboard I am troubleshooting died and I identified it is the discrete Nvidia graphics chip that has lost it's ways!
        So I removed it and now I am trying to change this motherboard to use UMA graphics, but I am having an issue interpreting the attached diagram. I have a 10K resistor in at the R2013 position and another one at the R2012. R2010 and R2011 are empty.
        The motherboard starts, the fan spins but no display. It turns off by itself. I restart it and it does start but stays on...
        08-12-2024, 02:01 PM
      • sikocan
        Lenovo X1 Carbon 9th Gen Black Screen
        by sikocan
        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
        SN: PF3G1REP
        MODEL: 20KW-00J1AU
        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
        06-24-2025, 09:01 PM
      • Friend33
        Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
        by Friend33
        I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
        06-16-2024, 03:13 PM
      • xxxchudyxxx
        How to transfer serial number and DMI data from bad HP BIOS to good one?
        by xxxchudyxxx
        i have a corrupted BIOS file from a laptop, but i need to recover the serial number and DMI info (like product name, UUID, etc.). I also have a good BIOS dump from the same model.
        Is there a simple way to copy the DMI data from the bad file to the good one?
        HP 650 G3
        Thanks!...
        06-24-2025, 06:28 AM
