Need help interpreting schematic of Lenovo B470 motherboard
  • rddube
    Aspiring Expert
    • Jun 2013
    • 958
    OK, so here is my issue.
    This Lenovo B470 motherboard I am troubleshooting died and I identified it is the discrete Nvidia graphics chip that has lost it's ways!
    So I removed it and now I am trying to change this motherboard to use UMA graphics, but I am having an issue interpreting the attached diagram. I have a 10K resistor in at the R2013 position and another one at the R2012. R2010 and R2011 are empty.
    The motherboard starts, the fan spins but no display. It turns off by itself. I restart it and it does start but stays on with no display.
    I also tried removing the inductor PL9201, but that didn't work either.
    Trying to interpret that diagram to have the right combination in resistors.
    Any help would be appreciated. This diagram is on page 20 of the LA47 MB 10250-2 SCHEMATIC LENOVO B470 B470C schematics.
    Am also including a copy of the schematics. [MOD EDIT] Link to schematic https://www.badcaps.net/forum/troubl...92-lenovo-b470
    Click image for larger version  Name:	Capture d'écran 2024-08-12 154235.jpg Views:	0 Size:	28.3 KB ID:	3327923
  • andrhouseolly
    Lenovo X240 - motherboard replacement for X250, no image.
    by andrhouseolly
    Friends. I beg you to help me in this situation.
    Lenovo X240 with a video problem. Native Intel drivers are not installed,
    after installation, a black screen. It works with the standard Microsoft driver.
    Understanding that there are problems with the video core,
    I ordered a motherboard from Lenovo X250.
    The laptop turns on, starts up, there is no image on the internal display.
    The image is output to the external monitor.
    I ordered another motherboard from Lenovo X250.
    07-12-2024, 03:02 PM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • Giggle2562
    Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
    by Giggle2562
    I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
    The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
    Here's what I've tried so far:
    • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
    • The laptop shows an image on the internal display for a few seconds before it shuts down.
    • I tried swapping the LCD panel with a known good one.
    • I tried swapping the LCD cable
    11-06-2025, 12:36 PM
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • laup
    Lenovo 330s-ARR-R332200U motherboard remove on board ram
    by laup
    ive looked through all the lines for 2311 but cant see a consistant row of them
    could someone please have a look at my bios and remove the onboard from within, appreciate it
    Laptop : Lenovo 330s 15 ARR
    motherboard: 330s-ARR-R332200
    SN: yd04qytm...
    10-01-2025, 07:23 AM
