820-01124 RIO MacBook Air 13" A1932
  • whizkidz
    • Feb 2021
    • 11
    • netherlands
    Hey all,
    Here are the schematic and board view file for the 820-01124 RIO board.
    file in BVR format
    enjoy
    Last edited by piernov; 06-09-2022, 07:50 AM. Reason: remove reference to commercial software
  • jipikiller
    • Aug 2020
    • 14
    • arg
    Re: 820-01124 RIO MacBook Air 13" A1932
    Thankssssssssss!!
    • Rickkap
      • Aug 2015
      • 123
      Thank you
      • Pedro147
        • Sep 2016
        • 152
        Thanks again for all your work @whizkidz
        My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
        • Bludeldu
          • Jun 2022
          Cheers for the RIO board!
          But I cannot open the .bvr file. What do I open this file with please? The open board view gives an error...
          thanks a lot for your work!
          • piernov
            • Jan 2016
            • 4435
            • France
            https://github.com/OpenBoardView/Ope...ases/tag/9.0.3
            • Bludeldu
              • Jun 2022
              Thanks for pointing me in the right direction! The Paul Daniels repository does not have the 9.0 released yet, so I somehow missed that.
              This helped me fix the corroded 820-01124 board.
              You are a heap of wisdom, thank you so much!
              • AL._.EX
                • Dec 2022
                • 834
                • Belarus
                Apple MacBook Air A1932
                Apple X1032 MLB RIO schematic
                PCB P/N: 820-01124
                SCH P/N: 051-00RIO
                rev: 5.1.0
                • elabas
                  • May 2018
                  • Netherland
                  Thank you
                  • alex780914
                    • Sep 2017
                    • 5
                    • Russia
                    thank you for your efforts
                    • venn88
                      • Jun 2023
                      • Россия
                      Originally posted by whizkidz
                      Hey all,
                      file in BVR format
                      enjoy
                      Spasibo
                      Thank you.
                      • Dwitty
                        • Jul 2021
                        • 21
                        • Earth
                        Thx!
                        • jipikiller
                          • Aug 2020
                          • 14
                          • arg
                          Thanks !!
                          • aliabdelgwad
                            • Nov 2018
                            • 5
                            • egypt
                            Thank you.
                            • joen_d66
                              • Apr 2013
                              • 57
                              • jakarta
                              Hey all,
                              file in BVR format
                              enjoy
                              thank you very much 🙂
                              • Lisa Jennifer
                                • Nov 2023
                                • 7
                                • Mauritius
                                Thanks very much
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                  Apple MacBook Air Retina A1932 820-01521 Schematic & Board View
                                  Apple MacBook Air Retina A1932 820-01521 Schematic & Board View...
                                  10-03-2024, 04:25 AM
                                • tony359
                                  2007 Macbook logic board fault
                                  by tony359
                                  Good day all,
                                  I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                                  Once the fan was swapped, I installed an OS and it worked fine.
                                  The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                                  Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                                  If I see that right, I have missed VCORE on L7100 (page 59)....
                                  01-23-2025, 06:59 AM
                                • bouch
                                  unlock macbook air A1932 2019
                                  by bouch
                                  hi
                                  i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                  i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                  i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                  have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                  I need help or information?
                                  Does anyone have the minat2 activator 1.4 software?
                                  Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                  Thank yo...
                                  03-12-2025, 10:14 AM
