hp 14-ce1002ne DAG7ADMB8D0 boardview or schematic
  • haroun
    • Mar 2021
    • kenya
    can i please get schematic or boardview for
    G7AD-2G please and thank you
    DAG7ADMB8D0 REV D
  • Eldiria
    • Oct 2021
    Re: hp 14-ce1002ne boardview or schematic
    Anyone have this? Have laptop but no display on hdmi or screen and 0v on a white fuse near hdmi.
    Any help will be appreciated
    • fairtone
      • Nov 2019
      • 7
      • Bahrain
      i want also HP G7AD-2G schematic or board view plz plz plz my laptop is dead
      • mon2
        • Dec 2019
        • 14735
        @fairtone, start a new thread in the repair laptop forum with details of your laptop.
        Sometimes schematics are not required.
        What is the fault? No power? Using the original adapter?
        • fairtone
          • Nov 2019
          • 7
          • Bahrain
          Re: hp 14-ce1002ne DAG7ADMB8D0 boardview or schematic
          yes bro i am using original charger but its not turning on i also checked the main mosfets and they are ok
          • fairtone
            • Nov 2019
            • 7
            • Bahrain
            i think its display wire have some shortage its making this problem but now i remove also display cable but still not turning on
            plz give me solution or board view or schematic plz
              • 22151
              The schematic isn`t available,and this is the schematics requests forum.Start a new thread in the main laptop forum if you want any more help.
              • fairtone
                • Nov 2019
                • 7
                • Bahrain
                thanks for reply bro i will check
                • SOMEYINGELSE
                  • May 2022
                  • porto
                  DAG7ADMB8D0 REV D
                  hi, i need help finding shematics or identifing this component. already try to replace for another n-type mosfet- still geting bsof after gpu driver instalation
                  • anshad
                    • Nov 2010
                    • 249
                    Probably won't matter even if you replace the original part. The short is more likely to have caused irreversible damage to the CPU/SoC by sending 20 volt directly instead of stepping down to a smaller voltage (close to 1v). Since you have mentioned BSOD after installing the graphics driver, i assume the PWM in question supplies core voltage to the internal graphic engine of the CPU (Intel HD Graphics). I have Seen this kind of CPU damage caused by shorted Mosfet dozens of time.
                    • manh trung
                      • Aug 2020
                      • 53
                      • vietnam
                      try... i think it's equivalent
                      frank martin
                      • christian100
                        • Aug 2021
                        • 15
                        i think it is only mosfet
                        on your picture you must not use the same part
                        • Pepito21
                          • Feb 2022
                          • 7
                          • france
                          thank you
                          • redman13
                            • Aug 2016
                            • 66
                            • bangkok
                            boardview
                            • vtkg
                              • Jun 2024
                              • 6
                              • VIETNam
                              Originally posted by redman13
                              boardview
                              THANKS BRO
                              • 0901036268
                                • Nov 2023
                                • LA
                                Please help me Hp 14 ce2041tu board view, schematics. thanks
                                • mard312
                                  Legion Go 8APU1 boardview or schematic
                                  by mard312
                                  I’m working on repairing a Lenovo Legion Go that suffered liquid damage. Unfortunately, one of the ICs on the motherboard burned out, and I haven’t been able to find any boardview or schematic for this model anywhere.
                                  Does anyone happen to know what this particular chip is, or have access to the schematic/boardview for this motherboard? Any help or reference would be greatly appreciated.
                                  11-12-2025, 01:01 PM
                                • AustinCER
                                  In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
                                  by AustinCER
                                  I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
                                  No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
                                  There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
                                  Any insight, schematic or boardview would be greatly appreciated.
                                  Model: Lenovo Ideapad Flex 5 14ALC7...
                                  11-04-2025, 03:49 PM
                                • PacoGT
                                  HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                                  by PacoGT
                                  hello firends
                                  i search the schematic or boardview
                                  I have this motherboard, but I can't find the schematic or the boardview.
                                  The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                                  So the computer doesn't turn on, and the 3V disappears after a few seconds.
                                  The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                                  The new problem arose after removing the bad chip.
                                  3V and 5V remained together,...
                                  08-19-2025, 08:25 PM
                                • hosain0489
                                  Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                                  by hosain0489
                                  I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                                  Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                                  If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                                  Thank you very much in advance!
                                  07-15-2025, 11:20 AM
                                • re-atari
                                  Gigabyte GA-H110-D3A schematic/boardview needed
                                  by re-atari
                                  Hello all,
                                  Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                  This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                  02-24-2025, 06:45 PM
