Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Provisor
    Re: Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Prov
    Attached the photo
      Originally posted by slimmy182 View Post
      Hi whizkidz,
      Inspecting the logic board I found this bad looking smd component just under the display connector, but I haven't schematics, can you help me please identify it to be proper changed? This A2337 show image in LCD but has no backlight at all and no detect internal camera
      @slimmy182, I have the exact same problem, same SMD. MAy you share on what you did to remedy this or what you did to fix this issue?
      I'm fresh out electronics and this is my first repair. Any advice would be appreciated.
        Hello, i have some problems to open the brv file... i just downloaded openboardviewer, do i need some plugins? Thx
          Originally posted by whizkidz View Post
          Finished the task of creating the board view file and cleaning up the schematic pdf file
          So if you find any error please reply here and will see if a can and/or want to correct them.
          So enjoy the work.
          Thanks for your hard work!
            Take a look
            https://www.badcaps.net/forum/showthread.php?t=102194
              thank you
                BoardView V1.3 not work.
                  Originally posted by nikemok View Post
                  here the schematic
                  please someone post the silkscreen
                  come on
                  d0gan your are right, here the revised version
                  Originally posted by piernov View Post
                  Fixed, R8313 pin 2 and R8318 pin 1 connected to MPMU_XOUT.
                      MacBook Air A2337 audio Board
                      Hi All., does anyone have the schematics for Apple MacBook Air A2337 audio Board P/n: 820-01929-A or if someone knows the values of these 5 caps (4 big same size & one small) Thanks in advance
                        Guys, never mind I got the values of these caps. The larger 4 caps are .01MF 25V & the smaller caps is 220PF 25v... My package for the .01 was not the exact pack, I installed the smaller pack & all worked fine. Audio is perfect. Thanks though
                          Bro... ur Awesome, thank you very much!
                            I have shelled out the cash for Flexbv and love it! But can't find the Flexbv version of board view and schematic for the A2337 800-02016.
                            Anyone have it or know where I can get it?
                            Thank you!
                              Thank you!
                              https://www.badcaps.net/forum/showpo...5&postcount=15
                              My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
                                Thank you so much for your hard work on the board view! Minor correction for a comming v1.4; RP603 is GND on leg 2, not PP3V3_SW_LCD.
                                  Yes, I just confirmed this on an actual logic board too. As far as I see it the schematic is wrong and this cannot be corrected AFAIK. Hence the board view is incorrect because I assume it is following the schematic. It's a tricky situation for @whizkidz
                                    I can fix the the boardviews, can't fix the schems though ( at least not yet )
                                    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                                    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                                      Originally posted by callmec2001 View Post
                                      I download the openboardview 9.0.3 but soon as i try to open it just close the app
                                      Try https://www.badcaps.net/forum/attach...1&d=1657726998
                                        Thx
                                          thanks for the work!!!
